Is it broken in and seating properly? Is there any dirt, or debris in there preventing it from moving over all the way. Check this stuff first before you write it off and get a new one. Joe
Mine didn't seat properly on my Tactical Blur. I tore it down and filed the contact portion of the lock and tang with my Sharpmaker rods. Locks up good and tight now.![]()
Uh, spine-whacking bad, mm-kay?Hi Kershaw guys, my new s30v blur is failing the spine-wack test. even against the palm of my hand. I would rather try and fix this myself if I can. is there a trick I can try? thanks
Yea, I'll give that a try and see. thanks guys.As spiral said, if you're comfortable tinkering with it ask for a lock side liner. Swap the current one out, and see if that makes a difference. If so, you're good to go. If not, I'd send it in.
