Blurry vision
Just recently got a Kershaw brand Blur folding pocketknife. This particular model is the new one with the cool looking brown handle and SG-2 blade steel. SG-2 is shorthand for Takefu's "Super Gold Powder Steel 2." It's used in high-end kitchen knives made by KAI Shun and Ryusen.
Out of the box, this knife had a robust decidely sharp edge. SG-2, as heat-treated by Kershaw, has a high hardness and high wear-resistance, so if you like the factory edge, you'll like it for a real long time. It also has a recurve so you can add more force to your cuts.
At the shoulder of the initial edge, it was about 0.022" thick from tip to ricasso. That's thinner than a lot of factory edges on 'tactical' knives. Still, if a Darksider sees a silk scarf sliced apart by merely falling on an edge, he or she will want to resharpen that edge or thin it out some more.
That's where the belt-sander came in! 40 grit closed-coat belt (thanks Gus and Bill!), 100 grit open coat belt, 160/45/16/6 micron Trizact belts, and a worn mylar belt loaded with 0.5 micron CrO/AO buffing compound made the bevel go higher up the blade and look oh so much shinier.
Now the bevel is 0.025" at its current shoulder, but 0.012" where the old one was and 0.006" right above the edge. Not Darksider-approved, but better than Ezra for my return to the beltsander, so I don't give a Sith.
Very comfy and secure in various hand grips and the liner lock is one of the more reliable ones I've seen. That tends to be a common trend in Kershaws. Now if only I liked liner-locks and framelocks... ...Lockbacks rule! Bababooey Bababooey!
Um, well, what's the point of thinning out the edge and making it shinier than Ned Beatty' mouf? Cutting! Just got a bunch of cardboard boxes to send to a watery grave and the Blur made them into a bunch of 4"x6" rectangles with no detectable loss in sharpness (which is to be expected from SG-2 yet still commended).
Things I didn't like about the Blur were the lack of a 'safety' switch and lack of a flipper for using the Speedsafe assisted opening mechanism. Without those two features, I'd rather just use thumbpower. The initial edge could've been thinner, too, like on the Shun knives, but few people are walking around using kitchen knives as their EDC.
Thanks, Broos! Don't know the listed hardness. Feels the same as S30V when hand sharpening and ZDP-189 when cutting. What I do know now is to add a slightly steeper microbevel/convexity than I had. :o It pwn'd cardboard with no issues, but got hoisted by its own petard slicing up a soda bottle. Had that happen much worse with VG-10 and almost the same with 13C26, but that happens. My buddy chipped a BG-42 Sebby doing the same. The plus side is that a microbevel may be applied with a $4 8000 grit slipstone.
YES! AMEN! PREACH IT BROTHER!
And thanks for the review. It is up to your usual standards of detail and usefulness.
nice review. maybe not as detailed (or should i say long?) as our buddy STR's, but still good. the pics are awsome, but the Star Wars referances are even better! " i dont give a Sith" priceless! can we see a closer pic of the edge bevel? that would be cool. oh btw, i do believe the RC is 64
Thom, you regrind primaries with a benchstone and redo bevels with a belt sander? You are an interesting guy.
Any comments on recurves vs straight edges?
-Cliff
How do you like this vs. your Caly 3 ZDP for edge retention and sharpness? You did some nice work on it thinning it out, being a lazy guy without a belt sander I would probably have send it off to Tom Krein to get it that thin. I second Cliff's question about the recurves, though the recurve on this blade isn't nearly as severe as say an Emerson Commander. I also second your motion that lockbacks rule. Oh yeah, and Bababooey to you!
Mike
Nice to see you got your hands on one too Thom.
Let me know how it holds up with that new profile.
By the way. I took the spring out of mine and its actually preferred that way by me now. I like it just fine as a regular everyday liner lock without the AO.
STR
Thanks all for the kind words.
Thanks, offsetlover, for the RC hardness. Will try to take a bevel picture soon.
Cliff, if this had not been a recurved blade, I would've used a benchstone instead of a belt sander. The recurve gives some wiggle room in case I misguessed how much blade was left to make the cut (most of my cutting is push-cutting). Well, on cardboard, anyways. The recurve catches stuff trying to run away from the edge, not unlike a hawkbill only without such a pokey ending.
Gunmike1,
I haven't used this knife long enough to dull it. Although both have a laminated blade with a high-hardnes, high-carbide blade, they're practically two different beasts. The Blur is larger in every respect and has a less delicate point and more belly.
STR,
Thanks for the Speedsafe info. Now my Blur doesn't thwack open and its pivot action is glassy.
STR
i did the same thing, only by accident. i was palying with my regular blur when the bar snapped. i havnt talked to Kershaw because, like you STR, i kinda like it as a non-AO knife. havnt gotten around to actualy taking out the bar.
thom your welcome!
Before adding a microbevel; and I do mean micro; the edge rolled while cutting a soda bottle. Now, it sliced a hula-hoop into twelve pieces (the recurved edge made it an easy task) with no damage or dulling. Harder, thicker plastic hitting the edge at all kinds of different angles and no rolling, chipping, or anything more than me feeling pleased.
:thumbup: :cool: A Fonzy moment, indeed.
There you go! My least blurry Blur picture. 10 times magnification
that would be cool.
Unfortunately, it was nerdy. And scratchy.
This has been my EDC for since the last post and it's so much better with the Speedsafe spring. Very silky action and a thin edge that cuts plastic, foil, and cardboard without dulling.
Yes it does. No need for the Speedsafe's spring (very thick piece of steel for a spring) to keep you from enjoying the silky action of the Blur. T6 and T10 drivers are needed for the screws, though.
Update:
Did I ever tell you how much fun it is to grind SG-2 down to a thin back-bevel, add a slightly thicker and highly polished microbevel for an edge and use it to cut thick plastic?
Well, the cutting thick plastic with the SG-2 Blur was very fun! We had a toy rocket over here that broke and needed to be put in the garbade. The SG-2 Blur understandably cut the foam and cardboard tubing with no troubles, but then it totally pwn'd all of the PVC piping! No rolling, no denting, no microchipping, no excessive force; just a little slice and then push-cut and sometimes just a little poke and then push-cut. The recurve helped add more force that the polished edge wanted to remove (polished here; the factory edge is a sharp and toothy edge that's understandably popular with folks who don't share my sharpening obsession).
I am very psyched. Have also heard rumors at the Kershaw Forum that there will be an SG-2 Junkyard Dog II. It's probably good that you can't hear the grunting and growling noises I'm making.
There are no pics because I don't want my wee one to see pictures of her old toy all dissected.
As a laminate you should be able to redo the primary fairly quickly, reduce the actual edge to < 0.0.10", especially with a 40 grit belt.
-Cliff
thanx for the review Thom.... :thumbup: yeah i'm real careful using my thumb on the thumbstud opening my blue Ti Bump.... it's kinda "hair-trigger" u know... ;)
I prefer flippers with the AO feature ...... I hope the JYD2 comes out with this steel though.....a must buy! :cool:
Are you Marvin's son? :confused:
Yeah, AO goes better with flippers. Then again, flippers don't need AO. IIRC, the SG-2 JYD II will have a ti framelock. We can always pester ThomasW when he returns from Hawaii.
Are you hoping that he meets up with Daywalker and inks a contact with him, too?
