I know this thread is old, but I thought I'd pipe in my experience with the KW exclusive BM 701-1401. First a warning, I'm no expert. My experience with wood, cardboard, and carpet had me retiring my knives for a $1 box cutter and $20 saw years ago... and I'm glad I did.
Any way, some pros and cons of the KW exclusive BM 701-1401:
Pros:
-All the Benchmade 710 goodness, e.g. Axis lock, quality, blade shape, etc.
-Nice blade steel
-The added milling on the edges of the KW 701 both round it out for high comfort, and adds grip when holding firmly. In fact, the milling in the KW G10 liners allows my finger skin to press far enough down to engage the liner milling (top and bottom). Unlike my stock 940 scales, I find that the liner milling is now functional on the 710 with KW's G10 milled scales.
-No backspacer to catch grime (colored standoffs... they can scratch/chip during disassembly if you're a lunk-head like me)
Cons:
-The stand-offs/pillars are not shouldered into the liners. The G10 milling of the standoff screws requires paying more attention during reassembly so that the Axis lock does not rub on the G10 scales. If the Axis lock rubs, it can cause the tip of the blade to be exposed outside of the handle while closed... about 1mm.
-Pivot screw threading is not very precise. I don't know if it's an issue with the thickness of KW's G10 scales (I don't have a stock 710 to compare), but I had to adjust it pretty loosely for no blade play (meaning blue Loctite is a must), and the coarseness of the thread makes adjustments rather imprecise if you're trying to find that perfect balance between blade-play and free drop for deployment speed.
Personally, I could do without the blue and black combo coloring, but it's OK. I love the feel of the KW's scales though. I'm attaching a pic of the edge milling:
