i got a BM 710 prototype today, blade marked prototype june 1998, and was comparing it to my std production 710.....both are std plain edge blades, no coating...
the handle material certainly looks different, no 'threads' like ya see in std G10,maybe bead blasted G10?? looks almost like micarta, still has the grooves cut on top/bottom of handle like the std 710 though, but handle is not drilled for left hand pocket clip placement, only 1 side, and it is placed little higher than the std - it has the older BM pocket clip, w/the small logo, no the large one like the std 710, and the thumb stud is about 5/16" farther down on the blade than the std model - also instead of the 5 holes drilled in the metal liner to reduce weight of the std 710, it has a large rectangular area cut out, proto seems to be a LITTLE lighter, enuff to feel w/your hand when comparing the 2...
also the std is marked ATS34 on one side, while the prototype is not marked as to steel type.....anyone have any idea what kinda steel it could be?? or what the handle material is??
how many proto's made?? any info??
i know go to the BM forum, just thought i would check here first, most on the BM forum are here too lol
thanks for any/all info, will post a pick later if i can lol
sifu
sifu
