Rough instructions on dissembling the 750.
Things needed
T6
T15
good quality grease
thread locker adesive
1. Take off the clip using T6.
2. Screw out the pivot screw using T15. Do not open the blade and lock the blade!!!
3. Screw back the pivot screw 3 turns and force the pivot out the other side. Notice that the pivot pin is notched and remember the direction of the notch.
4. take off the blade by sliding out the blade. Note that the washers are smaller on the locking side.
5. screw out the two spacer screws using T6
6. use a large screwdriver, pad the tip, and pry the liners apart.
Assembling
join the two liners using the stop pi as guide.
put in spacer and use a pin or screwdriver through the lanyard hole and spacer, and screw in the two spacer screws.
Note> turn the screws counter-clockwise until you feel a drop, then screw in. This is to ensure that the threads are matched. Also make sure that the screws are straight and align. Use a dab of nutlocker, just touch a bit on the threads.
dab a bit of grease around the washer, and stick them to the blade, the large washer on the side of the thumbstud.
use the padded screwdriver to part the liner a bit, between the stop pin and stacer near to the stop-pin. open the liner lock and slide in the blade.
Grease the pivot pin on the outer surface lightly, taking care not to get grease in the screwhole. use a small screwdriver to align the washers to the hole, slide in the pivot pin making note of the notch, from the clip side. Do not use force!! Just use the small screwdriver to wiggle the washer aroung until the pivot pin slide through.
Dab some nutlocker on the screw and tihgten then back off a qtr turn.
Hope this helps.
