- May 1, 2009
I thought since its a relatively new production knife I should step up and do a review on the thing. Let me start by saying i'm still not sure if I like the 760 right now its a love hate relationship.
Cant get pics to post so here is a gallery with all the pics: (includes pocket clip pic next to an Al Mar mini SERE 2000)
http://gallery.me.com/m6894/100045
I got it from a local knife shop and brought it home the factory edge was pretty dull from mid-blade to the handle, and the bevel was set very wide probably around or over 35 deg. Like an Axe or something.
The dull knife bit me first thing when I was making a cut on some cloth ribbon as you can see in the pics. I guess it wants to be truly mine as we started with a blood pact.
The first thing after I got my wound wrapped up I re- beveled the edge with a Lansky diamond kit. M4 is very nice to sharpen but the amount of metal on this thing made it take a really long time. First I removed some mettle on a 250 ice bear water stone. then I settled for 20 deg along the blade and 25 deg on the tanto point. on the medium and fine diamond I moved to 25 on the main blade and 30 on the point. Mainly because I was tired of grinding metal.
After sharpening....
http://gallery.me.com/m6894/100037/PICT0025
The BM 760 is a solid Ti Frame lock knife
http://gallery.me.com/m6894/100037/PICT0014
It locks up solid with an authoritative sound and was smooth after sticking the first 10 times or so. There is a tiny bit of blade play that seems to be lessoning the more I beat the thing up.
http://gallery.me.com/m6894/100037/PICT0017
The detent is a little weak (or maybe the blade to heavy) it will come open if you flick it hard enough. I don't think it would come open in a pocket though even if it was tip up. It takes a good swing to open.
I took it out back and chopped of a dozen or so small limbs from the hackberry. Hacked a few larger limbs 3/4-1" and sharpened a few sticks. Then batoned the knife into some treated fence and deck lumber. I think you could put this through a car door.
http://gallery.me.com/m6894/100037/PICT0020
http://gallery.me.com/m6894/100037/PICT0012
After the use in the backyard i came back in and cut some paper
http://gallery.me.com/m6894/100037/PICT0026
Its not as sharp but still pretty impressive.
The BM 760 is not a slicer I attempted to cut some cardboard just to bind on the blade 2-5" into the slice (pics first link). My 710 went right through this same box.
This makes it not so good for an EDC blade IMO.
(edit) Also you might notice the bk1 while a tough coating doesn't last long under use with all the high points on the blade.
(edit) As pointed out below the frame lock does make 100% contact with the tang of the blade, and has a small amount of wiggle. from looking at video on youtube it looks like it was designed this way but we will have to wait until some other people report back on there 760's
I would love to hear how the original Bob Lum Tanto II compares. http://www.boblumknives.com/images/folder8.jpg
