I recently purchased a 940-2 and put a 943 blade on it. After EDCing the 943/940-2 hybrid for awhile it fell pretty freely with little-to-no side to side movement. Recently, I received two sets of beautiful scales from Deathgrips (review when I have more time), and transferred the blades. Taking out the 943 blade from the 940-2 handle, I noticed black grit in the pivot area. I cleaned it and lubed it up.
I had no such issue with the 940-2 blade/943 handle/pivot hybrid. Similarly when installing the custom scales on the second 94x hybrid, the action was smooth as silk with no side-to-side play.
After reassembling the 943blade/940-2 knife with its new scales, I tightened the pivot just enough so the blade showed no sings of side to side movement. The blade came out a little stiff, but I figured that maybe I needed to keep using it for it to break in again... even though the pivot/liners were the same as before (broken in prior to disassembly). After about one week of EDC, it still hadn't loosened up. Today, I decided to take the blade out and check the washers to see if more black crud had built up, and sure enough there was (pics below).
As you can see in the pics, the black is being scraped off of the pivot (pic 1). Upon further inspection, the machined area of the blade the pivot mounts in looks to have striations/ribs (pic 2). So... is this normal? Will this eventually reduce the integrity of the pivot area?
Last pic is of the knife with my M9, of which I was trying to match the grips to. Great job Deathgrips!
Pic 1:
Pic 2:
Pic 1:
Pic 2:
