BM Stryker blade play???
I have a new BM Stryker 50/50 and have some slight right to left blade play when it is extended. I have not yet taken it apart to see if I can fix the problem, but I am interested in any input on how to fix it. I picked it up in a trade, so warranty is out of the question. Any help would be appreciated! :-)
David P Sproles
Eagle Scout Class of 1988
dpsproles@webbsrefreshments.com
[This message has been edited by Sproles (edited 03-24-2000).]
Tightening the screw will work maybe.
- Chang the Asian Janitorial Apparatus (Not a Communist :eek:).
If Benchmade did away with those nylon bushings I think that would help alot. If you tighten the pivot screw it should help, but then the knife will probably be hard to open (stiff). I would give Benchmade a call, they should still take a look at the knife for you. Good Luck
