Nuke,
The only problem is that I've read on several forums that the AXIS lock has a tendancy to rust out. Let me know if you have any experiance with this or any other AXIS
What do you have exactly in your mind, could you elaborate, please?
The Axis Lock basically is made up of 6 matching parts:
- blade tang;
- locking bar, what locks the blade opened being positioned across the path of blade tang;
- two so-called omega springs what force the locking bar into forward position causing locking;
- two elongated slots in steel liners the locking bar moves along.
Here you can see all this stuff. What exactly should
tend to rust?
I have at least 7 Axis Lock equipped knives, I carry some of them (mostly 551 Griptilian) on daily basis and so far I didnt notice any rust on anyone. On the other hand all steels tend to rust plain carbon steels faster, stainless ones slower. This is the only matter of conditions, just immerse your stainless steel construction in salt water, dont clean after immersing and I would be surprised if you wouldnt see any rust after few days. The sweat, blood and some natural liquids more work quite similarly...
So the solution looks quite simple for me: keep your knife clean, wash it in fresh water after immersing in aggressive liquids, dry them or blast with compressed air next, finally blast with some solvent-lubricant like WD-40 or something similar. Apply sometimes a drop of hi-tech lubricant into both Axis Lock slots, BENCHMADE recommends Militec one to maintain their knives and it works very well for me. However I suppose that each similar stuff wouldnt let you down.
BTW, dont apply too much lubricant, it could cause dust deposit on locking mechanism. Especially this touches Axis Lock knives what are carried with locking device positioned deeply in pocket, near its bottom where dust and debris gathers easily.
