BMs sharpening angle ?
Hi.
Sorry if this question was already answered.
I got BM recently and did some chopping (conifers). Now I would like to resharpen knife but since sharpening is asimetrical I want to be sure about angle of it !?
Thanks.
Kurdy,
You should have received sharpening instructions with your knife. Check the box it came in. However , if you didn't , search this forum as you will find many posts on the subject.
Tony
[This message has been edited by Tony Palmieri (edited 04-15-2001).]
The angle on the flat side is between 23 and 24 degrees. To sharpen, use a trailing motion with the ceramic rod on the flat side, drawing the knife from the base of the blade up to the tip. For the convex side, use a strop (leather, often impregnated with a polishing compound). The angle of the convex side is irrelevant as the strop will take the shape regardless. If you find all that to be a pain, grind off the the convex edge and sharpen it as per usual.
Thanks for the link! Good stuff!
"I like the desert, because it is clean."
