- Oct 7, 2006
Boar spear «Morse Taper»
№ 001
№ 002
№ 003
The assigned task: a finishing dagger easy to assemble on a pole, turning the dagger into a spear.
To avoid any discussion about the task itself and its practical application I have to make the following statement:
1. The task was set by a hunter who hunts wild boars with arbalest
2. The master is not a hunter, he doesnt know how to kill animals
3. And sorry for using not finally processed parts and units in illustrations
Ideas to use bolted joint or bayonet mount were declined as uninteresting ones.
The master did want to implement an old idea to use a method of mechanical attachment of machine taper (Morse taper) type.
The boar spear is a modular item consisting of the three main parts:
1. Dagger
2. Dagger sheath
3. Staff that serves as pole of the spear.
The item is complemented with a dagger waist-belt.
Assembling method was adopted from a widespread system for securing cutting tools or toolholders in the spindle of a machine tool or power tool - Morse taper. In that system a male member of conical form fits into the female socket, which has a matching taper of equal angle. Two parts reliably fix to each other due to dry friction and wedging effect. Thanks to this, the item can be assembled in a moment. But at the same time disassembling of such system requires additional equipment (remember how its realized in different machines). In this spear this problem is solved with a pushing out lever.
Overall dimensions:
№ 004
Component parts of the item:
№ 005
№ 007
№ 008
The pole of the item is equipped with two stop collars and zones of rhombic notches. The stop collars are collapsible, each of them composed of two half-rings set in a groove on the pole and connected to each other with coupling screws:
№ 009
№ 001
№ 002
№ 003
1. Dagger
2. Dagger sheath
Overall dimensions:
№ 004
№ 005
№ 007
№ 008
№ 009
