Wanted to boil the embedded factory oil out of a Norton coarse Crystolon to use like a SiC 'water stone' for coarse grinding, profiling, and bevel setting. For me, this kind of work with the coarse stone has been easier to do with water than with oil.
HeavyHanded
gave tips on process. Pretty simple but thought to document here for others' benefit.
Process I did:
Process I did:
- Materials as below. The 2 small tongs I placed on bottom of pan to keep stone off bottom. The larger I used to lift it out after scooping oil off the surface.
- Process:
- Fill pan to get water about 2 inches above top of stone when it's sitting on the tongs.
- Bring to full boil.
- Reduce heat, squirt 2 shots of Dawn into the water, simmer 15-20 minutes, then turn off and allow water to cool for a few minutes.
- Take a metal measuring cup or similar, scoop the pooled oil off surface of water.
- Lift stone out with large tongs and rinse.
- Wash out pan and all the tongs.
- Repeat the above process. For me, the first boil got probably 95% of the oil. The second boil still got a tiny bit more.
