Hi
Please could you Guys suggest well written educated article on what water purification is needed when backpacking
the risks and the solutions
thanks
I can't promise this will be well written and only have experience drinking water needing to be made potable aka not a chemist or biologist or Google search master. If it's winter I mostly boil because cold tends to do bad things to filters. Sometimes I will melt snow.
Other times I will collect it from small moving brooks/streams/springs that hasn't frozen over. Less work and risk. Remember water offers more risks than just illness. Be it melted ice, snow of cold water it's going to get boil. Cold alone won't make it potable.
For warmer weather I have been using this Sawyer Micro filter with good results.
Boiling also works well for warmer weather but it takes time. Best done in camp when resting not when thirsty during the heat of the day. As an added bonus often the water cools nicely during the night.
A fast drink out of a spring with my Frontier pro filter straw.
There are tabs on the market as well. I like using tab plus a prefilter aka coffee filter, bandanna etc. The prefilter also works great for those snow melt floaters. But read the tab's instructions as they can take time to kill the nasty stuff. Also keep track of the expiration date.
In addition I have several pump filters plus used bleach as well. Pump and gravity filters are nice for groups but can be heavier than necessary for just one person.
I think the correct amount of bleach is between 10 or 20 drops but forgot as haven't used it in years. If or rather when bleach leaks it's a mess. IMHO making water potable is a bit like sharpening a knife. You have to think a little about what's going on. The boiling, filters and tabs do a great job removing nasty little things. Some can't remove viruses or chemicals etc etc etc but then again what's your risk? Are you in a 3rd world country or the back country? I have activated carbon inline additions for the DIY Sawyer mini gravity filter but so far never judged that as needed for the areas employed. There are other things which activated carbon won't remove but again what's your risk? Knowledge of the area helps expose these risks.
I believe if someone purchase a good filter, pack tabs in case that filter fails and exercises common sense combined with knowledge of the area all will be just fine. If someone thinks tossing charcoal from a fire on moss then running water over that is going to actually work odds are things won't end well. Basically it's up to you. But on the flip side if you're ever really hard up for a drink and don't have any means to make the water potable do whatever yea can to make the situation better but in the end drink. You might or might not get sick days later however dehydration will put the hurt on long before that. Not sure of any article on the subject that stands out. Maybe see what the various manufactures of water treatment options have to say on the matter.
