Thanks!Really good looking knives.![]()
Ouch! That's a shame, because they are otherwise fine knives, mechanically speaking. I've been tempted to sand and wax one of mine, just to see if it makes a difference.I only had the whittler, and I returned it. It is the only knife that has ever given me a wood splinter. I once got a metal splinter from a Schatt and Morgan whittler though![]()
Not a bad idea.Thanks!
I'm not sure. I haven't worked with that stuff. Will it make the wood shiny and plastic feeling? I want the wood to still feel like wood.Not a bad idea.
Why not use polyurethane instead if wax?
Good point, you'd probably looses a bit of the feel , but maybe not all of it. I was thinking like a thin coat or two of satin finish min wax poly.I'm not sure. I haven't worked with that stuff. Will it make the wood shiny and plastic feeling? I want the wood to still feel like wood.
What you could do is, if you have some old wood lying around or scrounge some with a similar rough surface, use it for practice. Try sanding it with a 400-600 grit sandpaper, just to smooth out any really rough edges, then apply some tru-oil, rub it right in, let it sit for about 15 minutes, then wipe of any excess, and let it cure for 1 week. See how it turns out, the tru-oil should seal the wood, and if it is too shiny, buff it back with some 0000 stell wool. I have been experimenting on different woods to fill in time in lockdown, it's amazing what you learn and achieve. The tru-oil will seal the wood, but 1 coat does not change the appearance all that much. Just a suggestion, but you could just sand some old wood and see what you think.Thanks!
