Hello,
now have the Resurrection generation 2, here is my comparison:
First Significantly reduced by the weight of aluminum backspacer
(The focus of the knife is now exactly in the middle) also
may protrude through the Space Rendes the knife now
as a pressure point amplifier similar Kubotan be used, eventually.
suitable as a glass breaker, you should try.
Second The G10 scales are actually a little better grip than the Gen.1
(Taste).
Third The finish of the steel plates is cleaner (polished and no
sharp edges on the inner sides).
4th The liner sits solid (zero blade play), the blade passage
in my opinion are the same as the Gen.1 bronze washers
slightly lower than at Gen.1.
My conclusion: For perfectionists worth the purchase of the Gen.2
for the additional charge of 30 you get into this
Priced almost unsurpassable knife.
Anyone looking for a solid working folder is also Gen.1
well served.
Best regards!
