First of all, shop around if you're not in a hurry. I ordered my new one in cocobolo last month from a dealer who advertises here on the forum and it cost less than $55 shipped. Great value for the money, and you really do get the bangs for the bucks!
Everyone will have their own experiences and opinions, so here's mine...I have a set of large hands and the knife fits my hands okay. A little more heft would have been preferred, but would probably be too thick and heavy to be clipped inside your jeans front pocket. The knife feels quite solid and well balanced. The blade opens smoothly.
I've always preferred my one-handed folders to have thumbstuds, because it pivots and rotates the blade out more easily for me. The diamond textured thumbstuds are a nice touch and non-slipping. But after awhile, the textured thumbstuds will start chaffing the edge of your jean pockets. The clip does hold the knife nice and tight in your pocket, but as someone has mentioned before, it's only held by two phillips screws and there's a bit of play. These two phillips screws are quite soft and will easily strip.
The titanium liner lock is quite solid and has little or no play. The tension can easily be adjusted to your own personal taste via a small allen wrench. Unfortunately, Boker didn't take the time to finish the titanium bolsters a little better. The bolsters on my knife seem to have been just quickly done with a semi-rough finish. A smooth and polished finish would have been much preferred.
The cocobolo scales and the 440C blade is definitely the best attribute on my knife. The scales were nicely finished and oiled. The 3-3/4" 440C stainless steel blade is nice and solid. The blade came razor sharp out of the box and I was slicing newspapers from the get-go! The spine of the blade is nicely smoothed out. My knife must have been from the earlier version, so I have Walter Brend's flag trademark on the blade.
I did have one problem though...the blade tend to favor the clip side liner when the blade is in the close position. This began to rub after awhile. So I was about to disassemble the whole knife to see whether I had a warped blade. The first thing I did was remove the clip. Then I flicked the blade out and noticed that the rubbing went away. So, I immediately closed the blade and noticed the blade was back centered again. Even though there is very little pressure, the two phillip screws used to secure the clip (when screwed in tightly) will force the blade off center. This really shouldn't be happening, especially when you have strong titanium bolsters that the screws are threaded into.
As well, I also noticed that the slight gap between the (clip side) bolster and scale went away when I took the clip off. Everything was nice and flush (almost seamless). So, what the heck, I took the clip off (and kept it off) and just started carrying the knife in my jeans back pocket instead.
So hey, for under $55, this is quite a deal of a knife. Good luck!
[This message has been edited by Chubbs (edited 05-01-2000).]
