Bolster Finish
Rox
What would you recommend to restore a mirror finish on a tarnished bolster? I accidentally got some apple cider vinegar on it when doing a forced patina on the blade. Working lightly with flitz hasn't removed it. I am worried about scratching it by putting muscle into the polish. Any suggestions would be appreciated. Thank you.
Don't be afraid to 'muscle' the polish a bit. Flitz's polishing grit is very fine (about 3µ); as long as you're using a CLEAN rag/cloth, the polish won't leave any coarse scratches, and should only produce a high shine. Dirty rags used to polish may have gritty content on them, which might scratch (likely will, in fact).
Another idea: May sound strange, but re-application of some of the vinegar might help remove some of the stain (try it on a Q-tip). Just be sure to immediately wipe it off and completely wash it, to make sure there's no trace acidity left behind. If that helps take most of the staining away, try the Flitz again to finish it up.
If that doesn't quite get it done, some very light fingertip sanding with some high-grit wet/dry sandpaper should quickly remove the staining. Try some 2000-grit or higher first, which will produce a pretty high shine, perhaps with some very fine 'satin' scratches; then follow that with the Flitz polish again, to clean that up and bring the mirror back.
David
If using metal polish by hand doesn't work you'll either have to sand off the tarnish and then re polish or you can try a Dremel with a felt Bob and some polishing compound. If it's steel I've had excellent results on steel using the Dremel with Dialux green compound
