I have been reading different posts on this forum for a while now and use it to try and answer many of my questions. This is my first post so bear with me. If there is a link that might help me out then let me know. I have not been able to find anything while searching.
These questions are in reference to having to make two knives for a customer (about bolsters).I have talked to another maker about this and he gave me his method of doing it, but I am just seeing if there are other methods.
1. I am to use mosaic damascus bolster material which he supplied. How do you attach them to the blade and then be able to heat color them. I have always attached (peened) my bolsters (brass or stainless), pinned and epoxied the handle, and then shaped them together. I was told to screw the bolsters on (and possibly the handle), shape and finish everything and then remove them to heat color them (and then re-attach).
2. I also thought about not heat coloring one of the knives (bolsters) and just etching them. I have done regular damascus bolsters before and peened them with stainless pins, but after the etch, the pins were very noticeable. Is there a way to do this without having pins show after etching?
3. I saw a knife in the Jantz catalogue that had brass bolsters with two mosaic pins in them. How are the bolsters attached? Epoxied or JB'd along with the pins? How strong is that method if that is how it is done? I attach with JB Weld (just as a sealant) and peen well when I do mine.
Any advice would be great. Thank You.
