- Jun 28, 2019
Like the title says, which is the better of the two? Is Boltaron just better, no question? Or does Kydex still have something to offer that Boltaron doesn’t?
Thanks
Thanks
I've heard that Boltaron is tougher, and can handle the extreme hot and cold better. And as some of my knives are going to military personnel, I'm concerned about this. What are your guys experience?
Thanks
I posted the tech specs here once - the manufacturers put out technical data sheets
I believe that the Boltaron is cheaper, holds more moisture, but is available in more colours - camo and blaze orange were only in boltaron at the time I last looked at that.
don't trust my memory, go look up the tech specs
Kydex 100 and Kydex T
I believe you might have that reversed. Kydex is in way more colors then boltaron.
I use boltaron but it can be picky as it rolls up into a tight roll if you over heat it. I find that heating it slow in a pid controlled oven is a must.
