Cliff Stamp
BANNED
- Oct 5, 1998
The Becker Combat Bowie and Camp Tramp from Swamp Rat Knifeworks, were used to chop up a couple of Caribou legs which had been frozen overnight . The chopping was done at an angle of about 45 degrees, this maximises penetration and minimises stress on the edge. The cuts were done with a varying amount of force which resulted in the cuts ranging from two (near the hoof) to about twenty chops (close to the knee). The intended goal was to provide an edge durability benchmark to allow some comment to be made out the steel properties and geometry issues such as what kind of edge angle was necessary to resist damage, and how thin an edge could resist rippling. The results were unfortunately very high varianced. It was very difficult to reach a conclusion because of the significant variation experienced in cutting through one section of bone cut to the next, which was an issue mainly because there were only a few sections that could be cut, thus an effective average could not be well obtained. In any regard, the results :
The Camp Tramp cut through the first three sections of bone with no effect on the edge. However the next section of bone cut resulted in two chips being knocked out of the edge, one fracture was about 0.012" thick at maximum and the other 0.024". The next section of bone was again cut with no problems. In the region that the knife chipped the edge was ground at ~16 degrees per side and 0.060" thick. In reflection, the blade wasn't freshly sharpened and had been seeing very heavy use as of late, throwing and the like. Thus could have put the edge in a weakened state. As noted, the bone wasn't very uniform, it is possible that the one section that induced chipping was significantly harder than the rest. This kind of skew is easily solved by chopping a lot more bone and looking at the overall effect.
The Becker Combat bowie cut through all five sections of bone with no edge damage. After the cutting the blade still readily sliced paper as before. It didn't seem effected in any way. It was also a more powerful chopper than the Camp Tramp as it weighed more and is similar balanced. The edge is generally more obtuse than the Camp Tramp as it is ~18 degrees per side towards the tip, but does slim down to 15 degrees per side near the base, and that section of edge was used for the bone cutting as well. The edge is much slimmer than the Camp Tramp, going from about 0.035-0.038" thick. This would actually aid in making the edge more durable (speaking of damage which is less than the extent of the edge bevel width), as the thinner edge raises the inherent cutting ability at a given angle which makes for a smoother impact during a chop which reduces stress in a number of ways.
There is still some bone left and both blades will be given a full sharpening and the cutting repeated at a later date, hopefully with some fresh legs and other types of bone as well. I also have some large turkey legs and ham bones, and might be able to get some moose and caribou. In any case however, the Becker Combat bowie certainly did well, it could cut the bone near the hoof in one or two hits, and near the knee in about five clean hits, it generally took more as it is very difficult to get clean placement because of the extensive fracturing of the frozen bone.
UPDATE : note the comment below about the secondary edge bevel on the Becker bowie.
-Cliff
-Cliff
