Bone handle material
I'm thinking of using a piece of horse bone that I've had for years as a knife handle. It's very dense, hard and has only a small nerve hole down the middle, no marrow at all. It's from the foreleg just above the hoof I think, so it's strong. Question: It seems very oily or waxy. I doubt if epoxy will stick to it. Does anyone know if it needs any special treatment or can I use it as-is? It will be a stick tang, so I'm not relying on epoxy for anything other than gap-filler in this case.
Brian I would boil the grease out of it if it were me. With the apperance as it is it's probably got oil or grease embedded in the bone.
Do it outside in an old bucket or something and if you see any oil floating on top skim it off before removeing the bone when you're through.
crooked knife said:
Would boiling the bone make it more brittle or lessen its strength significantly?
It shouldn't, after it dries it should still be the same. Ever cook a hambone in beans? Same difference only this bone is cured.;)
I was thinkin' that simmering it for a while might get some of the grease out. Now my question, Yvsa, is whether or not to toss some beans and jalepenos in? Given thyat the bone is over 30 years old, my guess is NOT.
:D
Thaynks,
Part speculation/part experience, worth what it costs you:
Bone is more brittle than horn, may have to do with the fibrous growth of horn as opposed to ? celluar growth of bone. Dunno.
Shouldn't be an issue unless you have a lot of shocks/impacts/hits, I'd think.
If you are batoning the bejezus out of something, you might want to reconsider.
I've fractured bone while attempting to slightly force a tang into it. Horn seems to compress, and truly, the openings in the horn I've tried have always been bigger and filled with the adhesive or shim material which compresses.
As always, YMMV.
Kis
Thanks,Yvsa, Kis, et al,
The foreleg is a very dense bone and has probably been used for knife, sword, and tool handles for eons. It's a perfectly adaptable material. My only question was about the saturated grease/oil. I think Yvsa answered it.
I can't recall the particular source,
but I recall reading someone saying that they used
a white gas soak to remove grease from bone.
Usual cautions
& outdoors, away from anything & everything
gas explodes, etc, etc
might try a new chew-bone from pet store first
Can't see the gas harming the bone
Citrus solvent or turpentine spirits might work as well--
maybe a little slower, but safer.
Throw it in with the laundry?
:rolleyes:
Only read a couple
good luck browsing
search key at end of post
"The problem is that there are several types of lipid compounds in bones, some of which oxidize readily and are readily removed, others of which are part of the bone's structural integrity and should not be removed. Soaks in caustic chemical solutions destroy both of these groups and yield a white, greaseless, and often brittle or fragile bone."
http://biodiversity.uno.edu/~gophtax/_gophtax.96/1708.html
also:
http://www.ipa.min-cultura.pt/cipa/zooarqueologia/en/Bibliography/Simon/2003/preparing-skeletons.pdf
Stefan's Florilegium [size=-1]... Bleaching (in a weak bleach solution) is a good way to whiten and >de-grease the bones ... A good way of whitening/degreasing bone is boiling in soap solution. ...
www.florilegium.org/files/CRAFTS/bone-msg.html - 95k - Cached - Similar pages[/size]
[size=-2][RTF][/size] bone-msg [size=-1]File Format: Rich Text Format - View as HTML
... de-grease the bones and eliminate any remaining odor -- but be very. ... snip. A good way of whitening/degreasing bone is boiling in soap solution. ...
www.florilegium.org/files/CRAFTS/bone-msg.rtf - Similar pages
[ More results from [url="http://www.florilegium.org/"]www.florilegium.org[/url] ][/size]
http://cals.arizona.edu/pubs/natresources/az1144.pdf
"[size=-2][PDF][/size] Cleaning and Preserving Animal Skulls [size=-1]File Format: PDF/Adobe Acrobat - View as HTML
... the enzyme detergent, as indicated for cold water maceration, will de- grease skulls even ... Cooking too long can damage skulls and actually dissolve bone tissue. ...
cals.arizona.edu/pubs/natresources/az1144.pdf - Similar pages [/size]"
Household Hints From The Northern Cookbook [size=-1]... When it is dried well, one may eat pounded bone grease with it. POUNDED DRY MEAT Pound up dry meat for meat balls. ... Add bone grease and sugar, and mix up. ...
bertc.com/househol.htm - 16k - Cached - Similar pages[/size]
De-greasing Skulls
[size=-1]... off with various means, but I would like to know how to de-grease them and ... Theres
no brittle bone structure, much less teeth fall out or become loose, and the ...
www.taxidermy.net/forums/GameHeadArticles/VXGK_L.html - 8k - Cached - Similar pages[/size]
bear skull ?
[size=-1]... They are such greasy critters that if you don't de-grease them yer gonna be in for
a world of ... The bone stinks becasue it absorbed the smell of the rotting meat ...
www.taxidermy.net/forums/LifesizeArticles/ 04/a/041767E489.html - 10k - Cached - Similar pages[/size]
Bear skull shrinkage
[size=-1]... I use 35% tech grade, which is hard to find in less than 55 gal drums.Also if you
do not de-grease before whitening ... Bone white, grease free skull is the result ...
www.taxidermy.net/forums/GameheadArticles/ 03/j/0324CB88F.html - 7k - Cached - Similar pages[/size] Tail Trouble!
[size=-1]... Split it, remove the bone, and be sure to de-grease it! Have fun with
it! Return to Beginners Taxidermy Category Menu. If you would ...
www.taxidermy.net/forums/BeginnersArticles/ 02/j/028DB38D2D.html - 7k - Supplemental Result - Cached - Similar pages[/size]
from
http://www.google.com/search?num=100&hl=en&lr=lang_en&as_qdr=all&q=bone++%28de-grease+OR+de-greaser+OR+de-greasing%29&btnG=Search&lr=lang_en
google on:
bone (de-grease OR de-greaser OR de-greasing)
or
(old OR cured) bone (de-grease OR de-greaser OR de-greasing)
