- Jun 16, 2003
I was recently given The Backpackers Handbook by Hugh McManners (1995) as a gift. It was purchased at the local Borders.
It has much useful information and nice pics. BUT this got my attention[as in original]:
This seems misleading at best. Cotton does not transport moisture well and is legendary as a poor choice in cold weather. Even in 1995, there were far better choices for base layers in cold OR hot weather. He never seems to have heard of polypro, which had been around for years, or the wicking polyesters that were appearing on the scene in the early 90's.
And this is not just an infatuation with cotton. His "cons" ignore the fact that some cotton fabrics are quite wind-resistant e.g. "ventile"). It depends on the weave and weight of the fabric.
Finally, its pretty obvious that you do not always want to dress to "shed heat." And the ability to shed heat is at least as much -- probably more -- a matter of layering and zippers than "BEST FABRICS."
Perhaps its just a problem in communication.
CLOTHING
THE BEST FABRICS OFFER INSULATION from the cold and allow your body to shed heat and moisture. . . .
The Core Layer
The core layer which lies next to the skin should consist of a cotton vest or a long-sleeved thermal top. This garment should be close-fitting, but not tight or constricting. It should be made of a material that will absorb perspiration and "wick" it away from the skin....
[PROS]
Cotton is hard-wearing and able to "breathe, [sic] absorbing moisture. It is a good choice for underwear and any other item of cloting . . . that is next to the skin.
[CONS]
Cotton is heavy when wet, and items can shrink if dried too fast. A wrinkled cottom garment can cause discomfort is worn against the skin. Cotton is not windproof, may tear, and burns easily.
