Booshway-the Re-mix!
m. wohlwend
BANNED
I will let you guys name this re-mix... :D
I ground this out of the new steel I had shipped in to replace the L-6 I had...
This stuff is tuff! Beat on a large dried out log in the back yard. Then came inside and repeatedly chopped into an antler. No edge damage!
I didn't grind it as high as I normally grind the Booshway, then added a little swedging on the clip. Course being in charge of the grinder I can change all of this if it gets booed of the stage! :D
If you want a Booshway like this, then let me know!
I quite like the look of that. That grind would probably make it a better beater and splitter where as the full flat makes it better for slicing foodstuff etc !
This Booshway developed an attitude! Made of .220 thick new stock Admiral L-6, flat ground then transitioning into an convex to zero edge. Oh yeah. It's sharp!
hard to tell without a side by side pic, but it looks like it's either a longer blade, or a less wide blade than the Booshway. and it's apparently $25 less expensive, which leads me to believe there's possibly less steel in this one, or not grinding it as high means it takes less time.
looks cool, would love to see the two side by side.
I love the blade on this one, looks awesome. I'd like to see one with a birds beak pommel on the handle.
