Steve
If you have a vertical cavity forge the easiest solution I have fount is to make the forge with a removable bottom. Line the bottom with Inswool or Kaowool and set the forge back in place. When the insulation gets too bad, lift the forge peel off the old insulation, throw on a new slab and set the forge back in place. That being said, if you don't have the option of a removable bottom. you can try throwing a section of sheet metal in the bottom to catch the flux. This method is usually good for one heat, since the steel turns to iron oxide, which is what hot flux is used to disolve in the first place. Old cans that are not plastic or galvanized can be but open and smashed flat. Do NOT USE GALVANIZED, you body doesn't like zinc oxide.
Hope this helped.
Jim Arbuckle
