Boreal forest bushcraft: Siberian Fire
I was out in the Boreal forest this weekend. Temperatures were a frigid -25oC with very deep snow. I decided to try the siberian log fire. I was surprised to see how well it did in the deep snow. After it got started it didn't require alot of maintenance.
What is your favorite fire for the deep snow ?
[video=youtube;dAOba97KNY0]https://www.youtube.com/watch?v=dAOba97KNY0[/video]
Cool - Thanks for the vid.
best
mqqn
Rev - Looks like you had a great afternoon in the woods.
Are the three top angled logs above the fire to reflect heat towards the user?
Really nicely shot video.
Something doesn't look quite right to me about the fire though. The top logs look like they overhang too much, like they are almost half way over the fire, so if they burn through their ends will fall off and disrupt the ember bed. Having a search around I found someone else showing a bigger version but it shows how I expected the logs to be fed in.
[video=youtube;j7PSC4l0djk]https://www.youtube.com/watch?v=j7PSC4l0djk[/video]
Keeping the top logs more horizontal means you have a surface to cook on too. Logs are fed in gradually, same way you do with a star fire. The wide log that holds the top logs up acts as a heat emitter. Despite the common misuse of the term, nothing about any of these fires acts as a reflector. Logs get hot and re-emit, but all the ones that people talk about as reflectors only really work when they start to burn and are square on to the recipient, like infrared lamps. They don't warm you if they aren't pointed at you. This lay works by having that supporting log glowing and the ends of all the top logs glowing too.
Hope I haven't annoyed you too much...I hadn't seen this kind of fire before and it looks like it is a really good arrangement for that environment! Thanks for sharing.
Chris
Chris
Thanks for the comment !
It is true that what I showed might not be a classic siberian fire but it did wirk out pretty well
I will try your suggestions next time
Nice again video Rodger. I'll have to try this one next time I do some snow camping, which hopefully is in a few weeks. I used the top down burning fire setup on my last trip and it worked awesome, but it doesn't hurt to play around with other methods. Thanks for sharing..
Top burning fires work awesome in the snow !
Looking forward to see your pics or vid
