OccamsBlade
Jim Dobbler
- Jan 23, 2014
So I found a hardness tester on craigslist for a decent price. Thing is is that I don't know anything about them. I know it's a Rockwell/Wilson superficial hardness tester Model 3S. It didn't come with a manual, and can't find one online. This thing is ancient.
So first mistake I made (I think) was getting a superficial hardness tester, and it only came with 45kg of weight. I was wondering if this is still usable for testing hardened steel, that's if I can find more weights for it to get up to the required 150kg of weight? Or if a "superficial" tester won't work for knife making/hardened steel. It did come with a diamond penetrator and 54.55 45kg (45N scale) test block. So I'll probably need a test block that's around 60 (RC) 150kg (?)...if I can in fact even use this thing for knife making.
Also don't know what type of oil the dashpot uses. I assume it's the same type of oil you use for motorcycle shocks or the like. 10W oil. Some leaked out during transportation.
Thanks for looking and any help is appreciated!
