I can link to imgur when I get a pic.Any pics, they make a lot of blades.
I didn't know they had swapped steels! I knew they were 1095. I may have to try one again. Probably a small loss in edge retention, but if they don't shatter anymore, it'll be a big plus. Do you know when they made the change?have the same 22"... called a ct5, it's great (rather heavy to be called a machete, since it's pretty much non-tapered)
I use neon tennis grip for the handle, because they're not very good from the factory for heavy use unless you're wearing work gloves
...as for the 18" breaking - that was an issue since they used 1095 for quite some time... now that they've switched to 1075, I expect that will not happen
(1075, being under the eutectoid will not form carbides, which is why 1075 and 1070 are the most common steel for machetes)
www.bladeforums.com
www.bladeforums.com
Ontario has made the 18-inch model for many years on a U.S. Military contract. No imported blades, I'm not sure that would even be legal.Does Ontario make their own. Machete blades? A lot of manufacturers who want to add a machete to their lineup will purchase blades from a machete maker like imacasa or Tramontina, originally for a machete that will sell for $10-15. The knife maker will put a fancy handle on it, with maybe a sheath with extra pouches, and sell the rig for $45-70. As a rule, I steer clear of these hybrids, preferring to get my work done with the $15 Latins.
For $70, I’m thinking about buying a chopper, with 13-14” blade made of stock 5 or 6 millimetres thick.
Current specs on the OKC site say 1095 for the 18" and 12" machetes, 1075 on the 22". I'd buy a 12" if it was 1075.I didn't know they had swapped steels! I knew they were 1095. I may have to try one again. Probably a small loss in edge retention, but if they don't shatter anymore, it'll be a big plus. Do you know when they made the change?
