- Jan 27, 2008
I've just completed an order for three walnut paring knives that will be winging their way out to California on Thursday. These are destined to be Christmas presents for the three sons of a gentleman I met at the Sydney gallery where I display some of my work.
We had initially discussed a single knife as a present to himself, but later canceled that order. Not three days later he emailed to inquire if I could make three!
"Well, yes. I can."
We had discussed a price for a single knife but I felt that an order of three should get a little extra-special treatment. So I made simple matching boxes for each of the knives as a bonus. This man is a Arts and Crafts Movement(Morris, Stickley, etc) collector, so I designed the boxes with that in mind. The stock for the boxes has been in my shop for years and just happened to be of the dimension needed. I had forgotten just how gorgeous this wood is...... crazy quilting and lots of chatoyance.
I can't maintain proper temp for the heat treat of this 52100 steel in my gas forge so I used the Coast Guard College's high-tech electric kiln. I did not do the Ed Fowler triple/triple method, I just wanted to get the basic process right. This is the hardest steel I've worked with so far. Hand sanding to 2500 is quite chore.
The handle slabs have AMAZING figuring. I have a few book-matched slabs of this incredible walnut crotch-wood and I wait with great anticipation to see what a buffed oil finish will reveal. This selection did not disappoint..... gold, crimson, black, brown and beautifully chatoyant.
Anyway, here's the specs:
Boxed Walnut Paring Knives
Blade: 4", Flat ground, 52100 steel w/ 2500 grit hand rubbed finish, 1000 grit finish on spine. The tangs were heavily drilled for weight reduction.
Handle: 4 1/4" highly figured American Walnut crotch-wood w/ O1 steel pins. 1000 grit finish and buffed Beeswax polish(food safe).
Boxes: Quilted American Walnut w/ floating bottom and slide top. The toggles come from the same wood slab as the knife handles. Buffed Beeswax finish outside, no finish on the inside.
Thanks for looking. Please leave your comments.
Here's a few photos:
"Well, yes. I can."
