I think 1.75 lbs, is OK. Typical for a boy's axe is about 2-1/4. But many have reported great results from putting a light head on a longer handle. I have a 2 lb. that packs quite the little punch.
I have a 2 pound on a 28 inch, as well as a 2.5 on a 26, to provide to contrasting examples. They are both nice but the feel is different. for something like a 1 3/4 I might try a 25 inch. A shorter handle does seem handy for the types of tasks that a 1 3/4 is good at. I have a 1 3/4 on a 26 and I find it a tad long. I will probably re handle that one. The 2 pound on 28 inch is dandy though.
Awesome! im going to try to make myself an axe handle.. question, if i use green wood, should i paint the ends before or after i cut the kerf? and is the handle ready to use once the ends are painted?
Thanks!
What kind of wood are you using? I would paint the butt end, and leave that be. The other end is tricky, since you will probably be shortening a few times. Try to do all the work in a short time, like a day. Dont leave the handle too long. Putting an oild sock on end can also help a bit in lieu of paint. Just something to keep the air and sun off it works. Hang the handle straight, even after hanging. Dont lean it up or it will warp (certain types will anyway, maple is especially bad). after a week or so its usually dry enough to lean without warping problems. In terms of shaping, this rule might help you a lot. Keep the handle twice as wide as it is thick. The wideness being from edge to poll, thinness being from each side of the eye. For example, a 3/4 inch think handle would be 1 1/2 inch wide. I consider that to be an ideal width and thickness for usual use. You can keep it a little thicker but be careful thinning the width past 1 1/2. It can turn round in a hurry which I dont care for (though you might, and thats fine too).
Any questions, just let me know. Im happy to answer.
I was planning on using hickory, just because thats pretty abundant down here. Do you have any pictures of the 1 3/4lb axe on that handle? Im just worried that this axe head is a hatchet head and that it will look odd on a long handle. Its 6 inches long and has a 4 inch blade.
i think if a smaller boys axe handle is too big, then something like a gransfors bruks hunters axe handle would be cool.
6x4 seems like a boys axe. I wouldnt worry about it. I dont have any pics because of computer issues but that is getting fixed so I will get pics in the next week or two.
I should mention that this little 1 3/4 ive got is more of a hudson bay pattern, so dimensions are different.
I'd slap that 1.75lb head right on a normal 28" boy's axe handle and go to town. I've got one configured just so and it's a sweetheart.
http://www.bladeforums.com/forums/showthread.php/1005234-Warren-re-hang
There are some pix of it in the world in the 'axes in use' picture thread.
That looks really nice! i was planning on using this axe for camping/bushcraft stuff. Seems like the perfect size
I'm wary of handles shorter than 28" and longer than 15"... i'd probably figure out how to pack the longer handle or take a 1lb hatchet.
