- Aug 14, 2001
I ordered Brad's Manual Whip directly from Brad as a result of his post Monday morning (two days ago) in "The Knife Exchange" section of BladeForums.com. It arrived today. You can see a picture in Brad's post here:
http://www.bladeforums.com/forums/showthread.php?s=&threadid=167202
I am absolutely amazed by this knife! The picture doesn't come close to giving an accurate portrayal. First of all, the knife and blade are much bigger than I expected -- at it's widest point, the blade width is a full inch. Although the post puts the blade length at 3&1/4 in., it is actually almost 3&1/2 inches. The OAL length is just over 9 inches. Fit and finish are superb. The back edge of the blade is rounded by beveled edges which have been sanded, polished and bead blasted. The hollow grind profile of the blade tapers to a thin, precision, nearly flat portion, which makes up the final 3/16 inches (approx) of blade width adjacent the cutting edge.
The carbon fiber scales perfectly match the thick titanium liners, which are joined together by seven pins at an otherwise open back. The folder handle takes up nearly my entire hand and has a comfortably large weight with good balance.
Brad's description of his new Pivot/Bearing system as "super smooth" is accurate. On his website, he says the blade opens as fast as an auto -- I agree completly. Holding the knife closed, with the blade backside pointing to the ground, I can easily open the blade by snapping the pivot end of the folder/handle either in a downward or upward direction. The knife sounds an authoritative, metallic "snap" as the blade pops open.
This is one great knife!
