Brad southard
hi gents, so i'm owning two of these flippers now and was wondering why do they open so different ! i have taken them both apart oiled and lock tite all the screws and put back together with no problems,but find that one flicks open with ease and the other kind of drags! do the bearings go back a particular way!or will it matter,i'm thinking its the lock-bar tension but not positive!any others have this problem,thank you.:confused:
well i wonder if only the moron's like myself are taking there southards apart!am i really the only one !!:(
Yeah - see the 2nd thread link above. It was one of my favorite Spydercos but it didn't think much of me so I traded it in for a soul mate knife :D
I've taken apart my Southard a few times and it's always gone back together without trouble and flipped just fine afterwards. Not sure what's going on with yours. Lubed?
I like the Southards. I've had three; kept the black model, as I really like it.
I've taken apart a lot of Southards, probably more than most folks, as I have a pile of them and I have more custom scales for Southards than I have Southards, so I like to rotate the scales periodically.
I can tell you from experience that I've never handled a Southard that wouldn't flip reasonably well if it was put back together properly (assuming it hadn't been damaged). There are a few things to watch for, though:
- make sure you have the flat side lined up on all the round parts that have a flattened side (be particularly careful with the pivot sleeve, I've seen folks deform the pivot area titanium badly enough to mess up the flat spot in a way that causes a bump that will screw up the pivot)
- make sure to put the pivot assembly pieces in the same way they came out (if you can't get the knife to flip right even when centered, try reversing the pivot screw assembly)
- make sure the washers are between the bearings and the frame, not the bearings and the blade
- do the screw tightening dance -- I screw in all the frame screws and the pivot screw until they're screwed in, but not tight, then wedge some folded paper between the blade and the non-lock side of the frame, then tighten everything up and remove the folded paper, this usually has the centering perfect on the first try, but your mileage may vary)
- watch the pivot screw tightness
- if you have custom scales, be aware that small variations in the thickness of the countersunk area on the scale or LBS piece can sometimes mess with getting the pivot back to its happy place
In any case, relax, don't force things (especially if something isn't seeming to fit, remember those round pieces often have a flat spot) and just redo it until it's right.
I find a finger or two of scotch helps if it's going badly, but I give that advice as a solution to more problems than I should, probably. ;)
Here's an album of shots of some of my Southards, incidentally. I, uh, like the Southard.
Dayuummnmn! Nice southards evilgreg!
Blanex sounds like it's broken beyond repair just send it my way! Haha, but seriously I hope you get er back together nicely. I had the same issue and just sent it to Spyderco. Came back In good working order.
