Bradford Guardian 3.5 3D and Taco Sheath
I bought my first fixed blade EDC a few weeks ago. Generally, I like a nice thin blade because I don't tend to pry or beat on things with a knife blade. I really just use them to actually cut things (imagine that). I ended up going with a Guardian 3.5 in M390 with a full flat grind, black finish, and black micarta scales, and I ordered their Taco sheath to go with it.
I normally don't care for blades over 1/8" thick, but one of the things I was looking for was a tool that could serve dual purpose in a defensive capacity if need be. I assumed some kind of compromise was going to be in order. The Guardian 3 series has a blade profile that I really like for the way I generally use knives, and the 3.5 forms a nice guard behind the blade should I need to apply an abnormal amount of thrusting force, and everyone seemed to love the ergonomics of its 3D scales, so I figured it was probably a really good compromise to go with the slightly thicker 0.150 blade. After having it for a couple of weeks, I will say that everyone is right about the scales. They fit my hands extremely well.
The included leather sheath sucks IMHO. If they had offered the knife for $5 less without a leather sheath, it would be worth saving the $5. The sheath DOES look nice, but that's the only thing good I can say about it. Retention isn't very good, it won't fit on my belt, and I don't really like horizontal carry for EDC.
I have mixed emotions about the Taco Kydex sheath. On the up side, retention is excellent. I had hoped to carry the blade IWB at a slight angle from horizontal to facilitate cross draw with my strong hand, or (primarily) drawing with a reverse grip with my support hand. Before even ordering the knife, I wasn't sure this was going to be possible just because of its OAL. After receiving it, I think it's possible, but not with any of the sheath's that Bradford's has for it. They are far too wide. I would need to have one made that was stitched instead of riveted. On the plus side, the Taco sheath DOES work okay for pocket carry. The square-ish bottom corner does a good job of getting the sheath down into the bottom of my pocket and keeping it there. I carry it in my weak side front pocket (Walmart Wrangler jeans) with my keys and a Leatherman wave with no problems. I modified the sheath to form a hook that will catch on the edge of my pocket if I pull it out by the handle which works well. My other complaint about the sheath was that it didn't allow my index finger to be anywhere near where it should be. When modifying the sheath, I moved that edge to where my index finger is right where I need it to be. In hind sight, I should have left JUST a little more material there to keep the blade's edge covered while drawing. There's no risk of injury, but if I draw the knife quickly using the hook, the blade will cut into the denim ever so slightly as it exits the sheath and pocket. If I had left an additional 1/8" of kydex, that would not happen and I'd still be able to comfortably place my hand where I want it.
I do wish that they left the corners of the tang nice and sharp where it's exposed back by the lanyard hole. That would have been useful with a ferro rod. Instead, they broke the edge slightly. It make sense to do that so that the edge doesn't wear on a lanyard, but IMHO, the design of this knife is such that it doesn't need a lanyard.
All in all, I'm enjoying the knife quite a bit. When buried in cardboard, it doesn't slice as easily as a really thin blade, but it still doesn't take a lot of effort. It's extremely sharp right out of the box. I haven't used it enough to say that it holds an edge well, but I have no doubt the M390 blade will keep its edge for a long time. If I had it to do all over again, I'd buy the knife again in a heart beat. I'd just be a little more thoughtful before modifying the kydex sheath :)
If I can ever figure out how to add pics, I'll post some :)
The Guardian 3 series is great -- I have a Guardian 3 in Magnacut -- but I agree the leather sheaths are not ideal, and I don't like Kydex. I modified mine by slipping a spring clip through the belt loop and fixing it in place with a rivet so I can carry it vertically, but it's still a bit thick. I'm planning to make a compact pocket sheath once I can pick up some thicker leather than the latigo saddle leather I usually use. You might consider a custom sheath from one of the several makers on this forum -- Bradfords deserve a good sheath.
Bradford is my "go-to" FB for daily carry, even with the customs that I have. My Winkler SD 1 is the only knife that gives it any competition. I don't use any of Brad's sheaths, though. I like horizontal carry and Kydex, so I usually carry in an Armatus horizontal sheath. For pocket carry, I have a leather sheath from Oak City Leather Supply that works well with the G3 series. It can either drop down into a pocket or be clipped to the edge of the pocket. My fav G3 is an M390 FFG with CF textured scales (2D). The spine is square enough to use on a ferro rod.
I'm being called by a 3.2 in the same configuration. My resistance is weakening...
Bradford: Great knives, bad sheaths. On the leather sheath, there is no way my belt is ever going through that belt loop. The kydex taco sheath has almost no retention.
I have a G 3 and I ordered an Oak City Leather sheath. That finishes a great knife.
I agree. I contacted them to see if I could get one of the Taco sheaths that was only partially assembled (just prior to drilling for the rivets), but they very politely referred me to mashcat. Problem is that the mashcat website doesn't work, and I don't do fakebook, so I'm not sure how to contact them.
Their Taco sheath really does work well for me after modifying it some. If I can figure out how to get a picture on here, I'll show what I did and what I SHOULD have done.
A+ on the Armatus. Mine wouldn't get carried without it.
Me too. While the Guardian 3.5 blade isn't ridiculously thick, it's definitely thicker than I would normally pick for a knife of this size. (I usually don't want more than 0.125".) Thinking about some of the same issues as you, I decided to embrace the thickness and go all in on the tanto. I ended up loving it!
Heck, it even became my profile picture here. The handles are wonderfully comfortable. The transition from handle to blade is just right. Even if I reach for whatever thinner-bladed folder I'm carrying with it for lots of tasks, the points and wedges of this tanto are fun to use. It fills a particular role in my rotation and the only thing that could bump it is if they release the tanto in MagnaCut.
Interesting. My Taco sheath has TONS of retention. If I remove it with my thumb, the sheath launches itself pretty good. It it's original configuration, it was actually a challenge trying to remove it only using my support hand. After removing material to get my hand all the way up on the scales, it's a lot easier because I get much better leverage on the sheath. Still has great retention though. Maybe the addressed the issue?
I think the G3.5 Tanto would be a really good defensive blade, but I just don't like having to actually cut anything with a tanto blade.
So I had both of these with me today, both around the house and out for a hike. The little Wharncliffe did most of the work because that 2.5mm blade thickness is great for most of the stuff I normally cut. Whether opening a package, slicing up a box, or even cutting a cigar, the Dragonfly is an easy win. If I had to cut any straps, sharpen a point onto a stick, or do anything dirty or even remotely abusive; the tanto was there for me.
Longer term review (update). I've carried this blade EDC for over 18 months now. I still love the way it feels in my hand, and I still love the general shape of the blade. The taco sheath still has decent retention. The M390 steel, on the other hand, is for the birds. I started with a polished edge on it before finding out that M390 prefers a toothy edge. Since then, I've been running it at around 600 grit. When its sharp, its sharp. I used it last year to gut and skin a buck and a doe. Again the blade felt great in my hand, and the blade shape was VERY useful. The M390 held up okay to that chore, but I was expecting a little better edge retention. Since then and as part of its EDC chore list, it has opened a few boxes and it serves as my letter opener. It stays functionally sharp, but no matter what kind of edge I put on it, the freshly sharpened feel of the blade seems to evaporate after a few weeks, even if I don't use it, and I've found the M390 on this blade to have a very delicate edge. If it even gets close to a staple, it will develop a micro chip. I think Magnacut would be a MUCH better choice for this blade.
How many times have you sharpened it? While M390 can be sensitive to issues in heat treatment and can fall short of expectations on production knives in general, any steel can get messed up by the hot application of a factory edge. The reason that edge retention increases on subsequent edges isn't just that our skills are so good. It's that we are getting down to fresh steel with an intact heat treatment. How deep issues run can depend.
Also, yes, MagnaCut is the best choice from Bradford. They also use Elmax in some models, which I'd take over M390 any day of the week. M390 got famous and everyone wanted it, leading to lots of companies using it. While it is very stainless and capable of great edge retention, it isn't super tough and actually realizing that super edge retention takes care in heat treatment.
I've sharpened it a few dozen times. I found a staple on a couple of occasions, and that totally wrecks the edge. This was my first knife that was what I would consider "high wear" (compared to the older traditional steels). I won't go this high/hard again, especially on an EDC blade. Long term, it may get defaulted to skinning duty.
I wouldn't be turned off to "high wear" or hardness in general. Setting aside issues specific to production knives in M390, it just isn't very tough. Look at Larrin's ratings chart below, wherein a good heat treatment is assumed. Notice that M390 only gets a 3.5 for toughness.
MagnaCut is ideal in balancing excellent scores in the other categories with a 7 in toughness. That's part of the magic with MagnaCut. While Elmax only bumps up to a 4 on toughness, production knives in Elmax seem a bit more reliable in this context versus MagnaCut.
Potential HT issues aside, I generally prefer a thin, slicy knife. I don't tend to beat them on things, but I do occasionally find a staple or figure out some other random way to drag a freshly sharpened edge across a piece of metal.... That said, most of the time I'm using a fixed blade to process game, and I was thinking that a blade with really high edge retention would be a really good fit for me. I didn't realize how easily those steels micro chip. I would expect Brandford Knives to have somewhat tactically minded customers so in retrospect I'm surprised they offered anything in M390. That said, I am the one who decided to buy the knife, and in no small part because it was in M390. I think it will end up being a really good skinning blade for me, but that's about where I'll leave it. I picked up a pairing knife and 6" fillet knife this past summer in Magnacut. Both have a 0.060" spine and are 61-63 hrc. I didn't get a chance to clean any fish with it, and I've only used the pairing knife a few times but I've been super impressed with it doing a little food prep here and there. I'll be using both to process deer and pheasant over the next month so I'll have a better idea of how I like it after that.
The Bradford Guardian series does run thicker blades. They are far thicker than is needed or even helpful for most EDC tasks but they'll get a lot of jobs done. There is an obvious tactical or defensive appeal in the smaller ones, which seems to fit with the "Guardian" name. Especially as they get larger, there also seems to be survival or bushcraft appeal. The thickness of the blade is part of why I went with the tanto shape. It feels right.
