- Sep 2, 2007
Hi guys, sorry in advance for a longish post, but I have a small problem.
I just got my Alias II in the mail today and my first thought was, "hey what a ripoff, I got a knockoff instead of the real deal!", because it was so light in my hand. Having never owned a titanium knife before, I'm now pleasantly surprised that it's as lightweight as it is.
My question, which I'll pose here first before contacting NewGraham.com, where I purchased it from, is if anyone else received one by mail that had the pivot screw tightened down so damn tight. I've read some of you guys discussing this practice, so that it may clear customs hassle-free, and not be deemed a 'flick knife', but this thing is barely possible to open (with two hands, never mind using just one and the thumbstud). I'm off to the hardware store later to pick up a torx set to see if it's just a case of loosening the pivot.
My second question is if anyone else has ordered this exact knife before, and seemed to have trouble with the frame lock engaging. Mine, when opened, will resist slight hand force to close the blade, but to look at the frame lock 'engaged' you would think it would just close very easily as the lockbar is baaarely (as in, not even visibly) contacting the blade tang. There is no overlap that I can see, but it must be something, as it does resist closing. I'm sure the lightest of spine whacks would disengage the lock altogether.
I'm expecthing this to somehow correct itself once I loosen off the pivot screw a little bit, but until then, at first glance it looks as if either the lockbar or the tang needs a 'thou' shaved off of it before it will engage properly.
Thanks for hanging in through a lengthy question, and thanks for any feedback or help you might have.
