- Jun 1, 2016
Moderators...I hope I'm posting in the right place. If not, feel free to move this post. Thanks!
About 7 years ago or so, my wife and I came to a garage sale that had a box of old knives. In the box were a number of Imperial fixed blades (thin with plastic scales), a few Old Timer folders (nothing spectacular), and a number of kitchen knives. I bought the box for $10, then sold the kitchen knives (el cheap unmarked) and made back my investment. My son spied an Imperial that he wanted, with sheath, so I let him have it. It somehow made it into my shop, and ignored...until recently.
I was down in my shop the other day, doing a little bit of cleaning after a project. I looked over on the shelf under my box, and saw it sitting there, wrapped in a rag. Apparently, the scale had split, and my son didn't know what to do with it. Being now 18, he's been so busy, that he just set it down there and hadn't had the time to talk with me about it. I decided to start tearing it apart.
After drilling out the rivets...
imagur
This is after removing the scales, and a quick sanding of the steel under it. It had rusted over the years, and had a number of small pits that were large enough to know that it wouldn't sand out.
imagur
A close up of the blade stamp. Much of it has been taken over by corrosion and what appears to be careless sanding from way back. Even without the work Imperial visible, I am pretty sure that it's what used to be there.
imagur
After a number of passes across the 60 and 150 grit sand papers
imagur
I tried taking a close=up photo of the tip from the spine. It didn't show the corrosion that's there, but suffice it to say that I don't plan on sanding it all down.
imagur
Now, I'm a hobbyist gunsmith, so I have some bluing solution sitting around. I was curious to see how the blade would look in gun blue. I'm actually happy with how it looks compared to what it did look like. It's not a show winner, but it's better than many I've seen at garage and estate sales. I'll go through the bluing process a few more times to see if I can make it look better. There's a bit of overlap, which you can see on the blade by the handle. It's a wipe on solution, instead of a dip, so that happens at times. I'm not too concerned about it, though.
imagur
Now, I've never made handles before, but I'm pretty sure I can handle it. I guarantee that it won't look near as nice as others, but it will be serviceable. I thought about buying a piece of black walnut, or other hardwood, but just can't bring myself to put that much money into an otherwise free knife. I started digging through some older shotgun stocks, and found one from a mid 80's H&R 410, under a ton of dust and grime. I plan on cutting the stock up to find the wood I need. There's plenty of decent wood in it, so that's not going to be a problem, either. At best, the finish will be Tru-Oil and some final sanding when I'm done.
My daughter's boyfriend thinks I'm going too far for an old knife...that he'd just chuck it in the barrel and buy another one. Me...well, I'm medically retired, and bored out of my mind. Tinkering in the shop is about the only thing I can do other than being a Certified La-Z-Boy Operator (title given to me by my daughter). I have nothing but time and idle hands, and this is right up my alley. At worst, I chuck it in the can and move on. At best, I come up with something my son can use and hand down to his kids in the future.
