I know. I thought about buying wood then going to a shop but not sure what kind?eBay. But only if the planets align. The amount of luck required will be astronomical.
Get creative, or shell out to have someone more skilled create them. It sucks, but it is what it is.
I suggest stainless steel self-clinching fasteners and machine screws. They give adjustability with an attractive appearance (especially if using hex drive machine screws.) Self-clinching fasteners, sometimes called PEM nuts, are panel nuts usually used to add threads to sheet metal or circuit boards, which aren't thick enough to support threads. They are round but have an integrated serrated washer in their flanged base that allows them to bite in and prevent spinning in place. Looks very tidy when put together, and they're off-the-shelf hardware that's easy to find.I have a coping saw! And a wood rasp thanks. Any idea what ro use for rivets/pins to anchor to frame?
Before you mentioned using brass rivets. You can make a couple brass rivets from brass rod available at the hardware store. I made a couple 10 years ago by chucking up brass rod in a power drill (makeshift lathe) and turning them down.I have a coping saw! And a wood rasp thanks. Any idea what to use for rivets/pins to anchor to frame?
