- Aug 31, 2010
Would there be any problem with having a 110lb air hammer on the same slab as a Bridgeport milling machine?
I can't run them both at the same time, of course. The hammer is bolted down in one corner. I just got the Bridgeport.
The pad is about 12'x30'x6" thick, with a 12"x12" thick perimeter, poured well, about 50 years old. It's solid.
The hammer doesn't seem to jostle stuff on the pad much, but when I'm working large stock down, you can feel it in the ground 100' away.
The Bridgeport has digital readout, which is one reason I'm somewhat concerned. I need the Bridgeport perfectly leveled and solid, so I don't know if a guy can use some sort of vibration dampening material under it.
Thanks for any help!
