Brief Review: Cabela's D2 MiniGriptilian
I've been looking forward to a minigrip for awhile now, be it in a mundane 440C trim or an exotic S30V. I've also wanted a D2 knife, as, judging from what I read, it seems to be my favorite set of comprimises. Well, I finally have it.
I was initially turned off to this knife because of its relatively cheap appearance. I didn't expect FRN to accompany Benchmade's name and D2 steel. However, after getting used to, the minigrip has an understated appearance that appeals to me more and more. The blade of D2 minigrips has a matte black coating that I'm also not a fan of, but when matched with a black hilt, it really isn't so bad. I really wish they could have used a titanium nitride coating, which produces a gorgeously dark shine. Alas, they do not. Because of its very low profile apperance, this knife might be ideal for public use. All in all, a pretty good looking little folder, but definitely not intended for pocket decoration.
The feel of this knife, as its name might suggest, is excellent. I find this interesting, as, reaching for the knife, I don't expect it to feel good--I expect to feel gross hard plastic and all of its sweat-slippery propertiers. Instead I'm treated to excellent ergonomics and one of the most solid feeling knives I've ever used. Now, the FRN does not necessarily offer much grip, but the bulky shape of the hilt itself somehow does. Despite its simplicity, the ergonomics are excellent. It feels like a knife I could use for hours before getting uncomfortable. The solid steel liners no doubt contribute to this solidarity.
The action is excellent, almost as smooth as my M16. This is my first axis lock knife, and I'm enjoying learning the tricks of flicking it open and closed. Closing the knife is easier than with any other knife I've ever used, even if opening it only ranks second. It's definitely an addictively fun knife. However, I must ask--why, oh why, did they not give this a flipper of some kind? They even have a hole in the back for it. Flippers are definitely a huge personal preference of mine--they make opening a knife much easier and they also protect your hand in case of lock failure. I want to see this feature on this knife.
The axis lock itself is very effective and can be used ambidextrously. Interestingly, the lock must be disengaged before you can flip the knife open. You can still open it conventionally, however. One of the cool features of the axis lock is that you can flick the knife closed as well. I had heard stories of the axis lock accidentally being disengaged during use. I can't possibly imagine how this happened. Holding the knife in the way that I would use it, even if I try (really), I can't disengage the axis lock. The lock feels strong, even though I honestly don't trust it enough to test it like my M16, especially when it lacks hand protection. However, I'm certain it's quite strong. I am a bit concerned about stuff getting stuck in the lock itself, however. Only time will tell if this is a real life issue.
This is my first tip up carry knife, and I must say, it takes some getting used to. I personally prefer tip down, but at least the clip is solid.
The blade itself is made out of D2 steel and comes quite sharp out of the box. I can shave with it, but only just barely.
There is no play at all.
Despite a few shortcomings (FRN scales, lack of a flipper) this is a great little knife for 70 dollars. Definitely a great value if you need a good work knife but don't need all the pretty.
Very nice review.
The Mini-Grips are strong knives without a doubt and they will take alot more abuse than one would suspect.
Did you get the thumb-stud version or the thumb-oval-hole version?
Allen.
Artfully,
I recently bought a BM mini-Ambush.(2 things that stop me from EDC'n it are the rolling lock,scares me, and the thickness of the handle.)
Is this Griptillian thick feeling in the pocket or does it have a fairly slim form factor in your jeans?
I would love to get another BM, but will more then likely have to order it.
Thanks
WR
This may not sound that helpful, but I'd rate it as a moderately bulky knife. It's not really big in the pocket, nor is it small. However, you can reduce the knife by getting rid of the clip. I personally use the clip and am adjusting to tip up carry. I really don't feel it in my pocket when it's clipped. I'd rate it about average for loose pocket carry.
I hate to beat a dead horse, but if you want a nice thin knife, you might try an EDC M16, 3 inches. Very light, don't even know it's in my pocket.
Also, you can reduce the size of the knife if you get the non-Cabela's version and order it with the spyder holes instead of the thumb studs. I like them both, but I have a slight preference for the thumbstud. Nonetheless, things can get caught on them (like loose threads in your pocket). And it will reduce the width of a small portion of the knife.
I understand that you may have to order the Cabela's, as not everyone has one they can just drive to. However, mini-griptilians are pretty common here. I'd say one out of three stores carries them here. Try one of those--they should have exactly the same shape (if you use one with thumbstuds), minus the D2 steel. Then you can figure out if you like it for ordering. People might talk about 440C steel (used in the non Cabela's) but really, it's a fine steel for most people. It's probably the best non-premium steel. Me personally, I couldn't pass up the 10 dollar more switch to D2.
I have also heard of stories of the rolling lock failing.....pretty scary....but I recommend you find out for yourself--test that lock (with safety measures, of course). It might be stronger than we all thought.
Of course, you most definitely need a Cabela's too!
Thanks AM,
As you already know i have a M21 to fit the pocket.
But i am sure you already know too i am hooked, an need more edged implements, and feel i most definately need another knife, just not sure which 3 yet. :)
(Borowed from a Candle power forum signature)
I love the fit an style of my BM Ambush, And i have looked at that rolling lock, and really only a sliver of the rolling pin actually engages the blade tail.
(Oh and the size, it is a bit thick, whether materials determined the need for thickness or design,i dont care for it this way as an EDC.)
Again, i am not dismayed by my poor selection initially, rather encouraged to find the right knife for me now to fit into my rotation as an EDC.
I am all over the place with my writing so forgive me, as for the pocket clip, i dont want to give it up, since my first knife with one, i would feel i am missing a part of original function as a quick draw utility knife gives by not having one.(And for 20 years i have had a Schrade LB5 in my pocket bottom, and now i am hooked on the clip way, no change , keys or flashlights to mar finishes ECT...)
I will either try some tests on that rolling lock or return and possibly exchange for another at the place i purchased it.(Undecided)
Many thanks AM.
WR
Yeah, I'm a recent pocket clip switch myself. However, there is an alternative that most people don't seem to embrace, but I used for years--if your knife has a lanyard hole, you can put kind of a string through that. Hard to explain, but take a gander:
The reason I sometimes prefer this method is for self defense. The lanyard thing makes it pretty easy to find in your pocket and pull out for mundane tasks, but I found that when I was in certain undesireable locations, I could have my hand on the (unopen) knife exactly the way I would draw it, while both hands were in my pocket--and no one can tell. It's the next best thing to having the knife already out. This, in my opinion, is a nice compromise for loose pocket carry.
Now that I've adjusted to tip up carry, I'm starting to prefer that also.
I really think you might want to look into a 960 Osbourne. I absolutely love this knife, but I just can't reason with spending that much money for essentially the exact same thing as a Cabela's (axis lock, d2 steel, 3 inch blade). But my God, is it a beautiful knife. Here, take a look.
I've never carried it, but it feels a lot less bulky than the Cabela's. If you look hard, you might be able to find one for 120 dollars. There's one here for that. Most places though it's 140ish.
Did I mention it's beautiful?
Also, in your quest for three inch folders, let us not forget the budget Kershaws. I've definitely been impressed with the Kersaw Storm a friend of mine has, and you can find a brief review of that (from me) here also. Best yet, they're ~30 dollars. They have great actions for their price.
I can see it happening if you put your thumb and/or forefinger on the lock when using the knife. A hammer grip probably isn't a good idea with the Axis lock. There's a good reason why the back of the knife is milled the way it is. Your thumb belongs there.
Thanks for the feedback.
Was this an easy transition, not to sound funny or nothing to the regular tip up carriers, but i myself am a bit bothered by that design. Not enough to avoid though.
I mean, any concern to the Tip Up being possibly opened reaching for change in a hurry, or when hands are frozen because its -38c and your not at 100% awareness?
Hehe, that is one i really like, and have considered it a couple times now, would have to order that one in,however, i love the folder overall, not too threatning in appearance, and still has a kick ass steel,and styling scales.
Price will be high for this,and i am going shopping this morning for a couple more to add to my um, to my black bag.
An example of the price would be, a local retailer sells some BM's, they have an advertised 940 BM, and sell for $299 before GST,(Grab & Steal Tax)
I really wouldnt want to say what i spent on my kershaws,gerbers or CRKT's so far.
Damn, i am inflicted with many sins and curses, and one of the worst has to be the Instant Gratification Mode, I see It, I Want It, I Got It. Rinse an repeat for any other shiny trinkets of todays society.
WR
PS. Sorry For Hi-Jacking this thread everyone, No doubt I'm bad, and sorry. :)
Well, it took a couple of days to get used to, though I'm one of those guys that has to flick the knife constantly when it's new, so I was reaching for it like 20 times a day. Now, however, I don't even think about it. I was initially skeptical that tip up would be more convenient, but....I think it's my new preference.
Now, I shared your concerns for the tip of carry also. However, if you take a reasonably tightened axis lock in one of the stores and try and get the blade out without pushing down the lock, the blade takes a considerable amount of force. Better yet, try pushing the blade out less than one inch at the tip, and let go. It pops back in! In my pocket, there's not even room for the blade to go further than that, but I can't imagine it getting that far anyway.
Case in point, while it's hypothetically possible to hurt yourself using a tip up carry, with the axis lock based knives, I don't feel that this should be a normal concern. But I'll let you know if I cut myself any time soon.
