- Jan 21, 2000
Above photo shows a simple solution to a problem that has bugged me for years and thought some of you might benefit.
I like kydex. Maintenance-free and makes great non-bulky, lightweight armor for knives. But Ive never been satisfied with any manner of carry Ive tried with kydex sheaths. I know some people use tek-loks, but I dont like the stand-off effect which sets the sheath away from my belt. Its not streamlined, makes the sheath prone to hang/catch on brush or anything else I come in contact with when hiking/hunting, and makes the point tip inward against my thigh and the handle tip outward, accentuating the problem.
Also, when walking I dont like my arm bumping against my knife, so I typically carry a fixed blade behind my arm on my hip. With a sheath on a tek-lok, the position is fairly rigid, which means its awkward to draw my knife from that far back and a real pain to try and re-sheath the knife once Im done with it. To mitigate this, I carry cross-draw style, which lets me get my left hand on the sheath to tilt it forward and draw with my right hand, but its still awkward. Using a dangler or nylon web belt loop helps the rigidity problem but accentuates the problem of the knife handle tilting away from my body making it even less streamlined and, unless I use a tie-down, it flops and bangs around enough to be annoying when I run.
Several months ago I learned about the use of a static line from my friend Joe Paranee, who demonstrated the concept with a Paul Long leather sheath employing a stud for sash-style carry. (The term static line in rope lingo simply indicates a line that does not give, as distinguished from a dynamic line which is elastic.) It took a few months for my addled brain to make the connection but on a recent hiking trip to the Canadian Rockies, I tried using a similar line threaded through the bottom eyelet on a kydex sheath. As far as Im concerned now, its the only way to carry:
As shown in the photos, I just thread a length of paracord through the bottom eyelet of the sheath and tie it in a loop so that when it is looped over my belt, the sheath can pass between my belt and pants and ride with the bulge of the sheath-mouth resting on top of the belt. I cut the loop of paracord to restrict how far down the sheath can ride--when it hits the end of the cord it goes no further. I find that by positioning the sheath on the belt between the loop of cord and a belt loop on my pants, I can secure the position of the sheath so that it moves very little until I need it. When ready to draw the knife, I grasp the handle and pull--the sheath comes out smoothly with the knife. Then I use my weak hand to hold the sheath while I draw the knife or, if my weak hand is occupied, I just draw the knife with one hand when it hits the end of the cord. The sheath hangs at the ready while I use the knife, then I can use both hands to re-sheath and slip it back under my belt.
Among the advantages Ive found:
1) The ease, control and security of sheathing and unsheathing a knife this way is the best Ive ever experienced.
2) I dont have to remove my belt to put my knife on and off, which means I also dont have to remove a pack or pistol rig.
3) By varying the length of the cord (one way is by twisting it several times), I can shorten the travel of the sheath, which means on a longer blade I can secure a carry position thats high enough so I can sit without removing the knife (as when seated in a vehicle).
4) I can now securely carry a larger knife than ever before, hugging my body in perfect comfort, without it weighing me down or feeling awkward.
5) The knife and sheath fit so closely to my body that my arm does not touch as it swings normally when I walk, which means I can comfortably wear the knife farther forward.
6) Concealed carry, if preferred, is a breeze.
If you havent seen it, check out this thread in the Custom & Handmade Forum with a video showing Joe demonstrating the concept for concealed carry with a Jason Knight fighter:
http://www.bladeforums.com/forums/showthread.php/1130583-KNIGHT-Combat-Series-Prototype-Video
