If you used the custom search engine in the sticky, and typed in "Brine Quench" it will give you hundreds of threads with the info.
A 9% solution is .75 pounds of salt to 1 gallon water .... or .... 1 pound salt to 1.33 gallons water. Most folks make a mix with three pounds of salt and 4 gallons water to get sufficient volume. Warm the solution to 100-120F. I use a 7% solution which is 2.5 pounds salt in 5 gallons water. Others use 8%.
1084 needs a fast oil quench, and will gain nothing from a brine quench. If you are doing it for fun, go ahead ... but be prepared for broken blades.
BTW, there is a thread running right here in Shop Talk ( currently about four threads below yours) on doing brine and oil quench tests. It has the mix ratio in the first couple posts.
