- Aug 26, 2010
A few years ago we had a fire sweep through the town and of course my house was about half mile downwind from the ignition point. I did find my kitchen and first thing I looked for in the ashes next to my guns and a few other items was my knives. Here is a fraction of what I found and vowed I would somehow bring them back to life. I never found my Scrapyard Dogfather CG and some other large knives for some reason. but this is what I did find. Top down left to right: JA henkels Steak knives, Ax (no biggie), M1 bayonet, damascus staghorn bowie brass pommel and guard, JA henkels 8" chef knife, Cheapo Old hickory something or other?, 14" profesional JA Henkels chef knife, Camillus Khukri machette blank, Camillus Khukri carbon V blank with melted blob of aluminum, and another Camillus Khukri carbon V blank with many hours of hand filing and shaping entirely by hand. Urrrgh many hours there. Also many other knifemaking tools scribes, custom 2x72" belt sander from 8020 extrusion 2hp motor, sharpening steels, diamond hones....anyway was sickening to loose this stuff. SOOOOO! Today was a good day to turn things around finally!
I decided a good place to start was to the steak knife set (one missing). Since I have minimal equipment and no forge it might be possible to rebuild the small ones. Here is what I got to work with.
Map gas torch, can of motor oil, pliers (didnt need them), Magnet, (didnt need that either), and a stump. I found a sharpening steel I had fabricated a copper handle for that had melted around the steel so I know for fact that all this stuff had been baked at 2000 degrees minimum and annealed for about a week till it all cooled down enough for me to sift it out (yep i was barefoot).
The plan was to heat them then dunk them in the oil. Simple right! Nope. When I heated one part of the steel the other would cool so getting it uniform was impossible. I needed to keep heat on the tip while heating the bolster area so I decided to burn a pit in the stump and get it glowing red hot while heating the bolster at the same time and it worked well for the first knife. Cant tell in the pic because i was trying to get i pic but I did manage to get the edge very hot from bolster to tip and spine got less hot. I tried to point the flame so the belly of the knife would get the hottest like our Khuks are tempered and I be damned if it worked! I quench it in the can of motor oil and tested it for spring action and I was able to flex it considerably without bending it. Seemed simple enough so I repeated with the other two knives. Ha! Didn't work so well. They were definitely differentially treated. They would flex in one place and bend in the other. I finally figured out the right angle to hold the torch and get everything evenly heated and after the second and third try I got them all quenched. One is a bit springier than the other two but seemed fine!
I ran a file across one of them and the cheap chinese file would skate across like I hoped and the Nicholson file even had a hard time cutting but would do it! I then pushed on the sharpened edge and it did make a very small chip so they are in the oven right now getting heat treated at 450 degrees for a few hours.
If I can get them tempered enough to not chip I will one happy mofo! I have a piece of hard baked oakwood that was buried during the fire and is dense as heck so I am going to try to make handles from it if it looks reasonably good. If this works out well and even if it don't I am going to build a forge and do my chef knives next. Might even try the Khuks but really not so inspired to do them anymore since I found HI products. I can truly appreciate what the HI Kamis do and i haven't even began to touch what these guys can do. Hats off to the HI Kamis! Wish me luck my friends! Looks like ill need it!
