- Apr 8, 2013
Bowhunting is my primary hobby and, like most bowhunters, I'm always on the hunt for that perfect broadhead. For years, I've wondered why the majority of the heads on the market are made out of mystery steel. Sure, some heads are destined to be "one and done" tools, but I like heads that I can repeatedly use. I guess I suffer from a little bit of steel snobbery, and suspect more than one poster on Blade Forums suffers the same.
I came across Hunor Archery broadheads a while back, and thought I'd share the "Nimrod" model I picked up to try. I'm a compound shooter, but I still prefer fixed blade, cut-on-contact heads for the most part. Field experience points towards better penetration, and "cleaner" kills, for the most part.
What really drew my initial attention to these heads was the steel - M390. I've never come across a head made out of anything close. Getting them is a bit of a pain - the maker lives in Hungary, but I believe it was worth the wait. I haven't hunted with them yet. I plan on using them out of my Bowtech Prodigy for a bear hunt shortly.
The specs are as follows:
Blade material: Böhler M390
Blade hardness: 59 Hrc
Blade thickness: .059 (1,5mm)
Cutting diameter: 1,46/1,46" (38/38mm)
Ferrule material:
AISI 7075-T6 aluminium (125 grain)
AISI 1045 steel (190 grain) with brass ring
A 4-blade with almost 1.5" of cut needs a good bit of KE to deliver effectively, but the cut-on-contact design helps. They're built very well, and flying great. Should be interesting to see what they do to a bear.
Ferrule material:
