Broke the tip
bermo
Broke the tip on a Civivi doing something I should never do on anything but a Civivi.
Put a grinding stone in a Bridgeport, set the blade in a vise, and went at it.
Do what you can with what you’ve got left, most of us have been there.
Good recovery.
Just retipped an old Kershaw for a guy yesterday, came out pretty good. Dropping the point by taking steel off the spine is probably the easiest method, but reshaping the edge (like you’re doing, and I did) often results in a less weird looking profile.
Parker
Parker
The problem with attacking it from the edge side is that you usually wind up with a very wide bevel at the tip. On the plus side, you might need a way thicker tip if you need to replace your tip. :)
Looks like I'm not the only one with a missing tip.
Good thing there is more to use.🤟
Dude loves using his milwakees as a pry bar.... I just put an edge on it the easiest way possible n made up a name for it. I really enjoyed doing it is the weird thing. I also got him a pocket pry bar in d2 cause let's be honest no ti pry bar is gonna have a chance with him.
Usually I’m doing user knives, which the owners care how they cut, not how they look. But you’re right, I do tend to give them a stouter tip. I also do some full length blending passes to make the transition less obvious.
Parker
