Thanks for the additional info folks, I think I'm gonna try the torch a bit--and yes Andrew, I was trying to drive it out from the bottom up. Unfortunately there weren't any pieces to grab ahold of Count--it broke clean through about 1/4 of the way down in the hole.
What are taps generally made of-HSS? this one looks like it was cast from something, it was a Bosch black oxide tap.
They
should be HSS
But is this what you have ?
https://www.boschtools.com/ca/en/bo...-tap-and-die-sets-b44713-2610941901--33155-p/
It lists as high carbon steel.
HSS has been in use for fifty years plus, the only reason for high carbon steel is to make that set cheap and sell it to you at max profit
All those crap taps should be crammed up the nose of the store wholesale buyers that fill hardware stores full of that junk
A tip for you and anyone reading later
The tap and die sets in hardware stores are crap
They are full of sizes you will never use and the quality is crap
The sets are full of hand taps, which come in three styles
Taper, plug and bottoming
You want a taper tap to start a new thread in a new hole
But the indidudual hardware store taps and the sets are ALWAYS the middle tap style a plug tap, which makes it much much harder to turn and results in breakage.
Go to an industrial machining supplier and buy a good quality HSS
Spiral Point Tap in the size you need
Not a "hand tap"
If you have no one locally
McNaster Carr
MSC
Enco
KBC Tools
Travers
Sowa Tools
The $4 for the tap you need.
I find it hard to break a 1/4" 20 tap
I can power tap in the drill press with the same tap again and again.
Ive written about this before, try and search for similar posts I've done and you might get photos of the taps and more detail
