- Oct 31, 2020
My grandson broke the tip off the warncliffe blade on his 62 half congress I gave him 5 months ago. Any ideas? Any estimate to have GEC replace that blade?
Thanks. What about the heat from grinding, it won’t affect the heat treat.I'd just grind the spine down until it meets the "new" tip![]()
Heat management when grinding hardened steel is always critical for sure, but it's definitely doable without harming the heat treat. If your not comfortable/proficient with a grinder then sending it out or doing it manually with stones/files as Gary mentioned is another option.Thanks. What about the heat from grinding, it won’t affect the heat treat.
I did that on a Griptilian. I started with a file and then dressed it with stones.I actually reshaped a broken tip of my D2 Spyderco Para using just a diamond stone. Yes it took longer than it would with grinders and sanders but it worked. I actually like the tip more now than the needle like original
Wow, thank you but I’m in AustinI agree with Chip, except I would use files or stones to do the work, if you are not too far away I'd be happy to help out.
G2
G2
That sounds great! Helping hands and great advice is part of why I joined this group. Thank you!Include enough to return the knife back, probably $5 would cover it
G2
Gary, you've always been, and continue to be, a great asset to this community.You're most welcome, it would be less than a days time to finish and get things back in the mail for you and I'd tune up the edges if they were in need of sharpening as well.
G2
Let’s take a moment also to appreciate the grandfather who gives his grandson a traditional folder, which grandson obviously uses. How old is the grandson btw?My grandson broke the tip off the warncliffe blade on his 62 half congress I gave him 5 months ago. Any ideas? Any estimate to have GEC replace that blade?
