Brother Tuck, the walking Stick
Hello,
how to recognize real people like us if you are in the woods and fields and the mountains on the way ....
Yeah right on a walking stick. The knife so you can see only at the second glance.
I have to build me one before the holiday still made ​​it.
Did it for the first time worked properly with the plane. I've made ​​tons of chips which was really fun.
Stock length of 1.30 m is walnut.
The bar is on the cross section considered processed drop shaped.
So forward and around the sides Cuneiform flattened. I found the most sense of the stability and weight . I did not look for the floor just planed straight, but he should have as a slight curve.
My experience from the last walking stick made ​​of bamboo with titanium tip and winding Paracord I could incorporate into the new year.
Paracord as winding looks great but I found it for long walks hand can be uncomfortably warm. There is no ventilation. I have the leather grip for better ventilation of the hand inside and slotted front stitched thick.
The leather handle is a bit longer than two hand widths. This one has the advantage that you make use of the cool leather on longer hikes.
Everything tested and works. On top of the floor, I put a piece of yew.
The end is made ​​of nickel silver with Brass and Epoxy glue safed.
Here are the pictures:
Regards Dirk
I like it! I am not a walking stick kind of guy,but looking at your craftsmanship and design I immediately saw all of the different uses it would be capable of. If I saw that in a gear store, I would buy it. That's saying something for me.
