- Nov 29, 2000
o1 and mild steel?? Greg Nealy (MS Houston) said, I swear, he used that same two steels in his cut'n bend test blade for his MS! If'n so, what'd I do?? forge at to low a temp? Obviously what cracked was the o1 as the mild stuff is damn near impossible to mess up. Additionally, when you are making up a damascus billet, do you take an angle grinder to the surfaces, i.e. "get to white" before you tack weld the corners or do you just leave'em lay so to speak?, with whatever finish they (the steels...) left the foundry with? Does it make a difference in your heat welding what condition the surface of the components are in other than rusty'n scaley?? I normally use o1 and L6 to great success but I've got to come up with something these ABANA people can find and experiment with.
regards, mitch
regards, mitch
