Atlas supplies, Premium Knife Supply, and Maker Material supply have it. Just google "Pink G10 Rod" and a few sources come up. Etsy, Ebay also have it, usually from one of the aforementioned sellers.
Ok, you may need to check with the suppliers. It's hard to tell if it will match, so you may need to get scales and pins from the same supplier and make sure they know that they need to match! I've seen places calling the regular pink as bubblegum pink online as well? Not sure if it's just how it's polished/treated after it's finished or if it's an actual different material.
If it needs to match, you may need to get extra scales and use a lathe to turn a section of the scales down into pins? Or use a hidden pin method?
Ultrex G10 Pink Rods are made from Grade G-10 material, known for their superior mechanical strength, and electrical characteristics.
atlassupplies.com
I will say Atlas is good people. They'll make sure the material matches if you tell them it needs too. And if you hit a certain dollar amount, you'll get free shipping. Also, not sure why, but they also have an ebay store that's sometimes easier to find what you're looking for.
Thank you but I'm trying to match the more obnoxious pink. I have both colors of g10 in sheets and I suppose it is a little bit purple if I look at them together.
