- Aug 5, 2005
Buck 110 Dual-Blade "custom"
(This is the 2nd dual blade "custom" I have done; see the thread "Inside a New 110" http://www.bladeforums.com/forums/showthread.php?t=378651 for the first one)
Disclaimer: I am not a knifesmith, and only do these crazy "customs" to satisfy my offbeat whims. I do not make or modify knives for $$$. There are *real* knifesmiths on this Forum who do; if you are interested in having them do a knife similar to this, feel free to contact them and use this thread for inspiration.
OK; after the fantastically successful
dual-blade 110/112 [copy of the 110/112 Transition knife], I was interested in another 110 "custom", this time with a 110 clip-point blade, and a 426 drop-point blade...So, I used some of the leftover parts from the first dual blader, plus the parts from a stripped [and reshaped] 426...and a home-made center divider, made from .060" brass sheet...
Everything had to be fitted, and when I was happy with the way things looked and worked, I used some temp pins to hold it all together...
Didn't look all that bad, so I fabbed some 1/8" brass pins, and one 1/8" steel pin, and assembled it all again...Then I pressed the brass pins in [actually, the pins were a slip fit, but with my new arbor press, I crushed them in place]...The steel pin is a "floating" fit, with a very mild peen on each side...
I then milled the brass pins flush, power sanded most edges flush, and buffed every surface I could to get rid of scratches...
Here's the finished knife...
There's still a couple fine scratches, and the steel pin doesn't want to buff out, but it came out much better than I expected...
Next: My 3rd effort...a drop point dual blade knife, using a 426 main blade and a reground [to drop point] 112 secondary blade...
