Buck 110 easy opening ideas?
Anybody modify their 110 so that it is a one hand opener besides the one armed bandit that is mentioned in prev.post. such as drill/dremel a section from blade? Or use an actual flipper that you can drill through. One armed bandit idea is great , I just want something more permanent.
Check out knifekits.com for supply's to drill and finish hardened steel, as well as thumb studs and other accessories.
Put it in the pouch with the tip down,when you remove it grab it by the spine of the blade and kind of flick it downward.If you practice this you will be amazed at how fast it is.
I have no problem opening it without any modification - it require five minutes or so to learn how to do this.
Thanks, Vassili.
