Buck 110
I was feeling a little nostalgic and I picked up a Buck 110 today. I could pick it apart and compare it to modern folders, but no. Instead I am just going to enjoy it and here's why.
Quick disclaimer... I turned 50 this year and so did the Buck 110, hence the nostalgia.*
-I remember this being "The Knife" to have as a teenager
-It feels really good in hand
-It is heavier than I remember, but that's good
-It puts a smile on my face when I hold it
What's your opinion?
* Actually we both turned 50 last year
Got a custom shop 110... and love it! Happy 50th brother--wishing you another 50!
I've owned many different 110's over the years and now still have a half dozen or so that I haven't given to friends and neighbors. This is my favorite:
Pretty Buck knife pictures! Thank you.
To the OP: I carry a Buck 110 in my fanny pack.
I like Buck small fixed blade knives too.
I got my Buck 110 at 64 years old. The simple anniversary edition. I will be 65 years old this summer!
Cate
guys, what's your opinion of the finger groove version as against the standard handle? i've small hands, btw and i've better suited to the 112.
...Perfect timing to pick up a classic :thumbup:
-I've got a 112 from way back. I sold it to a guy at the time & then really wanted it back,
so i ended up buying it back from him. :) -Cheers, BTB.
There is a reason it's been around 50 years. Not sure how many I have owned or still own but it's a classic that I enjoy using.
I think the 110 was my first "real" knife. I received it from my step father about 22 years ago for deer hunting and still have it to this day. I put a really nice edge on it back when I was 12 and it still surprises me how sharp I got it to this day. Also have a commemorative buck 119 that a family friend gave to me.
I'll let you know.. ;)
I have a Buck custom shop 112 on the way, It'll arrive tomorrow !
I have been waiting for 5 weeks for mine ! :thumbup:
Brass bolsters, Finger Grooved, 420HC, Walnut, with pins
and Let me tell you, the decision between 420HC & S30V was a nailbiter.
I think if it puts a smile on your face, that is really all that is important. I have a couple 110's myself, but always preferred the Schrade USA version to use.
As posted by AllenC on Bladeforums.com Oct. 4 2006
AllenC said:
Where to begin....
I suppose it really depends upon how you use your knife.
If you just need a sharp object to open the mail or cut the occasional loose thread, then you really don't need more than a simple $3.00 dollar "box-cutter" (and replacement blades are very cheap too so you don't even need to buy a sharpener).
But if you want cutting performance (not chopping, not prying, but cutting), then the Buck 110 is very hard to beat.
It's all about the design....
The Buck 110 is simply one of the best designed knives of all time.
Consider the handle:
The handle is nearly perfect in size and shape.
It fills the hand just enough without being to wide or too narrow, and there are no sharp edges to the handle that might cause a blister or hot-spot.
The Buck 110 handle was made for long term comfort for hours of cutting.
I've never known anyone who thought that the Buck 110 handle was uncomfortable to hold and to use.
In thread after thread concerning the subject of "comfortable knives to use" the Buck 110 is always named and recommended.
And the Buck 110 handle is secure in the grip too.
And if does not need to rely upon "traction grooves" or rough texture...the design of the handle itself makes it secure in the grip.
Even covered with deer blood, it is secure.
Consider the lock:
The lock-back design has proven itself to be reliable, safe, and long-lasting for nearly forty years.
The lock-back is even used in many of today's most modern folders (like the Spyderco Manix).
Is it the strongest lock on the market?
No.
But it is more than strong enough for a folding knife of its size.
I have never known anyone to break the lock on a Buck 110 without doing something that they knew they should not have been doing with a folder.
It simply will not "just break" with normal folder use.
Consider the price and origin:
The basic Buck 110 can be had for about $30.00 dollars....and it's a USA made knife!
There are very few USA made folders, of equal design in comfort and performance and durability, for that price.
The Buck 110 is truly the working man's folder.
No one is ever ashamed to be seen with a Buck 110.
Consider the performance:
The blade geometry and design of the Buck 110 is simply fantastic!
The precise needle sharp tip and the high hollow-grind, combined with that comfortable handle makes for an incredible cutting machine.
Even the basic Buck 110 with 420HC blade-steel will out cut many knives with superior steel.
And when you step up to a Custom Shoppe 110 with BG-42 or ATS-34, or the Cabela's Alaskan Guide 110 with S30V, you have a knife that can stand toe-to-toe ,for cutting performance, with any folding knife its size....bar none!
Oh yeah, and it's beautiful too!
To address a few concerns....
It has no pocket-clip:
True.
But this not necessarily a negative.
Pocket-clips are handy to be sure, but they also have their drawbacks:
The can cause hot-spots and blisters (especially during long-term cutting).
They can scratch furniture and damage things too.
They can catch on things and dislodge the knife from your pocket.
And they advertise that you're carrying a knife.
On the other hand, the belt sheath is not only secure and comfortable, but it also protects your folder from being affected by pocket debris (lint, coins, keys, etc...).
I've carried pocket-clip folders for years and the clip always catches more than its fair share of abuse.
Still, if you simply must have a pocket-clip, one can be added aftermarket.
It is not a "one-hand-folder":
Well, this is simply not true.
I, and plenty of other folks, use our 110's with one hand all the time, everyday.
It just takes a little practice.
No, it's not as quick to deploy as a dedicated one-hander, but it is not slow by any means.
It's not like opening a Victorinox Soldier, or getting to the blade of a Leatherman SuperTool....
I can draw my 110 from it's sheath and have it open in my hand in about 4 seconds.
And I've never known of any situation, where I needed to cut something, that a couple of seconds made a difference....and if a few seconds DID matter, it would be better to carry a fixed-blade anyway.
It's heavy:
Yeah, the Buck 110 is a little heavy, but not to the extreme.
It is only about 1.5 oz heavier than a Spyderco Manix.
About 2.5 ounces heavier than a Spyderco Police.
And only about 3.5 oz heavier than a Spyderco Military.
And the weight and heft give a certain inertia to some cuts....like a nicely weighted golf club.
I own Cabela's Alaskan Guide 110 in TiNi-coated S30V. It's a classic design that I love.
I wouldn't be surprised if 80 % of the people on this forum have owned one for a while. I've had mine for about 30 years + or - a couple.
Yessir, the Buck 110 is iconic, a timeless design that works well and looks good, too.👍
I agree, the 110 is a great knife for just about any age user. It was my first "serious" knife and I still have one in my collection. :thumbup:
I bought the 110 for a trip I was taking, and didn't want to spend a lot on a knife that TSA may take. I got it new for a steal IMO, 30 bucks and it's the sterile 50th anniversary model that's a bit rare. I never planned on liking it. The 110 soon kept me company on any trip or outing I took.
I don't have any other folder with a sheath. I didn't think I'd use it, but I only carry it in the sheath. I never feel it, and hardly notice I have it.
What makes it different though than any other folder? That's the magic of the 110. A perfectly designed blade in every way. A knife for the common man.
I really really really want to get a custom shop one. It's in the plans this year, but we'll see how that goes. :)
I love mine, too. I'm just a few years younger than the OP, and I always had a couple cheapo 110 knockoffs around. But I never went ahead and got the real thing until the 50th Anniv. models came out. I like 'em so much I got a couple of 'em. Notice the different tang stamps - I'm sure somebody can explain the change. They must have started with the design on the top-pictured knife, and then realized that the knife didn't actually say "Buck" anywhere on it, so they changed the stamp to the one on the bottom-pictured knife. But that's just a guess:
Oh, and I went ahead and picked up one with the finger grooves as well while I was at it. I didn't care for the grooves much, so I gifted this one to a buddy in need of a strong folder (plus, it goes quite nicely with his Henry Golden Boy rifle!):
Go to the knife makers part of the forums and look under the services part for JAG Customs he specializes in 110's and has made the baddest custom 110's I have ever seen. Am going to start sending him some of mine for thumb studs.
